POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 05 Nov 2007 (Monday) 20:32
main purpose of filters?
implayaz9
Nov 05, 2007 20:32 |  #1
i have been new to photography and have been using a 20d. few people have been recommending me to get filters with whatever lens i get. my question is what is the main purpose of the filters?.. i know it helps protect the lens from hitting direct sunlight but there got to be more than that it can do. i am planning to get a 10-22mm and was wondering what kind to get or how many different types are there and what do they do?
20D | 28-135 IS | Sigma 10-20 | 50mm | 17-40 L
Familiaphoto
Nov 05, 2007 21:32 |  #2
Well, there are lots of reasons to get filters. The most common reason is to provide protection to the front element of the lens. Now, there is a lot of debate on this. One school says put a lens hood on and you'll get all the protection you need, the other that a filter of some sort should be used.
Protection filters are usually of the UV type. Keep in mind that the UV part adds no benefit as the CMOS sensor in your 20D already has a UV filter on it. The benefit is protection. If you do get a protective filter get a good one, especially with the lens you mention above. I would always recommend a Hoya or B+W MRC. These are great filters that won't degrade your image quality. A cheap filter will definitely degrade image quality.
Just to finish off what was mentioned above, there are reasons to get filtes beyond protection. This reason is image enhancement of some sort. For example many of us use Circular Polarizing filters to enhance the blue in a sky and make it pop. Just one example, but you get the point.
Best of luck.
Paul
Blog (external link) | Gear (external link) | Gallery (external link)
Bag Reviews: Domke F-3x | More to come...
implayaz9
Nov 05, 2007 23:08 |  #3
ok.. thanks for the info. more info would help too..
dicktay
Nov 05, 2007 23:18 |  #4
This may help.
It's a link to a filter manufacturers web site.
http://www.tiffen.com/​camera_filters.htm (external link)
Tony-S
Nov 05, 2007 23:20 |  #5
I only own three types of filters: circular polarizer, neutral density and gradient (gradual) neutral density. There's no reason to own any other for digital photography, as all others can be emulated with post processing.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
JWright
Joined Dec 2004
Nov 05, 2007 23:59 as a reply to  @ Tony-S's post |  #6
The people telling you to get filters... Do they work for camera stores, by any chance?
John
implayaz9
Nov 06, 2007 00:04 |  #7
no but people who have been shooting for a while are tellin me!.. when u guys get these filters do they work for any lens or i have to buy one specifically depending on the lens?
rcg
Nov 06, 2007 00:44 |  #8
Filters are kind of an old school attitude... as mentioned there are specific reasons. In my case I run them where I can for protection... shooting racing tends to get you sprayed with pee gravel and rubber shards. Having said that the big lenses 300/2.8, 400/2.8, 500/4.0 etc don't accept front filters and they hold up just fine with hoods only.
Rob
WebSite (external link)
dicktay
Nov 06, 2007 00:48 |  #9
I buy a UV filter and lens hood for each lens, I believe in protection - others don't.
A polarising filter for each lens thread I have as some lenses use the same size thread.
I also use a cokin type system for ND & ND Grad filters so it is only a matter of buying the adaptors.
implayaz9
Nov 06, 2007 00:57 |  #10
i have a 28-135 mm and planning to get 10-22mm. so u guys would recommend me to 2 different filters for each lens?.. that way it will protect the lens as well as would have to swap from time to time.
SkipD
Joined Dec 2002
Nov 06, 2007 03:09 |  #11
implayaz9 wrote in post #4261720 (external link)
I do NOT recommend filters for "protection" unless you will be shooting in hazardous (to a lens) conditions such as blowing snow, rain, etc.
However, I highly recommend your buying - and using all the time - properly designed (for each lens) rigid lens hoods. The hoods will improve your images by blocking stray light that can reduce contrast and add flare to the images. In addition, and a little more important to me, rigid lens hoods add a tremendous amount of physical (as in bumping and even dropping the lens) protection for the lens.
Skip Douglas
Crossfire
Nov 06, 2007 03:30 |  #12
It is a personal preference, and mine is to use them. Filters do provide some added protection, as most people have seen photos of lenses that have been accidentally dropped and only the filter was damaged. It can also help protect the front of the lens from sand, rain and other elements of nature. The downside is that some believe filters can result in degradation of IQ, as you are adding another layer of glass to the end of your lens.
My only advice is that if you do decide to use UV filters, buy good quality ones, e.g B+W MRC UV Filters.
pointView | photography
www.pointviewphoto.co.​nz (external link)
implayaz9
Nov 08, 2007 10:48 |  #13
ok cool. thanks.. quick question..
what filters do u recommend me for:
10-20mm
28-135mm(already have a UV promaster filter but will get other if recommended)
10-22mm
.. and where do i get these filters?..
r.morales
Nov 08, 2007 12:49 |  #14
B+W filters .
http://www.schneiderop​tics.com/info/handbook​/ (external link)
Reasons I use filters
1 . protection
2 . It's easier to clean filter than lenses
3 . easier to use a filter than photoshop .
4 . someone sneezes , water - wine dust , etc - it's a lot faster to change a filter than clean a lens and miss a shot .
5 . The people that say don't use them [filters] put front and rear lens caps on the lenses not on their camera -[I hope] for same reason you should use a filter . If lens protection wasn't important - none of the manufacturers would spend the money to supply them .
6 . I already own probably 40 to 50 from film days .
My advice buy the best you can afford - try to get brass - most of mine are tiffen and Hoya [NOT BRASS] - but thats because of film days .
I just bought a B+W UV and KSM CPL - after taxes about $200 with change .
scot079
Nov 08, 2007 14:03 |  #15
Tony-S wrote in post #4261303 (external link)
I agree, buy the best you can afford and I MEAN THE BEST! If you get a $1K lens and put SH!T glass in front of it, you're wrong. B+W all the way...well we'll throw some Lee in there for variety:-)
CPL
http://www.bhphotovide​o.com …mm_Kaeseman_Cir​cular.html (external link)
ND
http://www.bhphotovide​o.com …etails&Q=&sku=8​087&is=REG (external link)
GND
http://www.bhphotovide​o.com …6_Graduated_ND_​Resin.html (external link)
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
2,972 views & 0 likes for this thread, 11 members have posted to it.
2058 guests, 142 members online
