Thread started 06 Nov 2007 (Tuesday) 14:18
need alternate lens hood recommendation
JChin
Joined Jul 2004
Nov 06, 2007 14:18 |  #1
Mostly I want something narrower since I have a 20D.
Can someone recommend an alternate lens hood for my 24-105L?
Does anyone know if the EW-83DII (for the EF 24/1.4L) would work and is it narrower?
Can someone recommend an alternative lens hood for my 20/2.8 and 50/1.4?
I want a petal style hood, do they exist?
Thanks.
Johnny J. Chin ~ J. Chin Photography (external link)
Facebook (external link)Flickr (external link)SmugMug (external link)Zenfolio (external link)
I shoot with Canon gear.
Grentz
Nov 06, 2007 14:30 |  #2
The hoods are designed for the lens...if you got a different shape/smaller one it would not be effective for the lens.
Search.TechIslands.com (external link) - Photography Shopping Search Engine
www.TechIslands.com (external link) - News and Reviews
My Gear List - 60D
Mark_Cohran
Joined Jul 2002
Nov 06, 2007 15:44 |  #3
In terms of alternatives, I don't think anyone lists any. As Grentz noted, the hoods are designed to work effectively with a given lens (or set of lens in the case of standard length primes).
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
simwells
Nov 06, 2007 16:48 |  #4
Yeah no-one ever seems to have compiled much of an extensive list of hoods for different sized sensors.
JChin
Joined Jul 2004
Nov 07, 2007 03:07 |  #5
I was hoping someone on this forum has tried alternative hoods and can give some comments.
gofer
Nov 07, 2007 03:17 |  #6
Grentz wrote in post #4265007 (external link)
Not necessarily. The lens is an EF and therefore it and it's hood was designed for a full frame camera. If the lens is being used on a camera primarily designed for EF-S lens then arguably the standard lens hood on an EF lens could be more effective if it was a different shape to take account of the smaller FOV.
Steve.
JChin
Joined Jul 2004
Nov 07, 2007 03:21 |  #7
gofer wrote in post #4268652 (external link)
Exactly ... you've got my idea ... I want something smaller (narrower diameter); so it fits my camera bag better too.
Anyone with a recommendation?
I was considering maybe a hood made for a 35mm prime lens on the 20mm, if the size fits. Or the hood from 85mm lens on the 50mm prime. Does anyone know if it fits?
simwells
Nov 07, 2007 03:26 |  #8
JChin wrote in post #4268663 (external link)
If anything the lens hood will likely be larger as the outer diameter will be similar so it'll actually mount to the camera but it'll be longer to cover the longer FL
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Nov 07, 2007 03:32 |  #9
simwells wrote in post #4265665 (external link)
No one other than this....http://www.burren.cx/p​hoto/alternate_hoods.h​tml (external link)
simwells
Nov 07, 2007 03:44 |  #10
Woolburr wrote in post #4268691 (external link)
14 lenses isnt exactly an extensive list though is it?
SkipD
Joined Dec 2002
Nov 07, 2007 03:58 |  #11
JChin wrote in post #4264955 (external link)
Think about the physics for a moment.....
The hood on the 24-105 MUST be able to allow the angle of view at 24mm on a 35mm film camera. The EW-83DII MUST be able to allow the angle of view of its 24mm on a 35mm film camera. What difference would there be? How could it possibly be a significantly narrower hood?
What you want to try to find for the 24-105 (used strictly on an APS-C camera, that is) would be a hood that is originally designed for an EF lens of approximately 38mm (at the short end if for a zoom). Because the 24-105 uses the EW-83H, that tells you that you need the EW-83xxx design to mount the hood.
That said, I can tell you from experience that not all EW-83xxx hoods fit all lenses using EW-83xxx hoods without some rather finicky modifications. In order to use an EW-83DII on my 16-35 f/2.8L (which comes with an EW-83E), I had to modify the "threads" in the EW-83DII to fit the lens properly.
Skip Douglas
JChin
Joined Jul 2004
Nov 07, 2007 05:23 |  #12
What about alternatives for the 50/1.4 and 20/2.8?
I looked at the Canon hood for the 50/1.4, it isn't a petal; do they make a petal one that will work?
Would the EW-78BII (from the 28-135mm lens) work on the 20/2.8?
mrfourcows
Nov 07, 2007 05:47 |  #13
simwells wrote in post #4268723 (external link)
yes, but i believe that you only need alternate hoods for wider lenses. on telephotos? come one. plus, there may not be so many lenses that can accept alternate hoods - mainly the L series lenses i believe.
gear | flickr (external link)
SkipD
Joined Dec 2002
Nov 07, 2007 06:30 |  #14
JChin wrote in post #4268932 (external link)
What's the importance of the petal style to you - merely to "look cool"?
The only reason that some hoods are carved out to the "petal" profile is to reduce vignetting at the corners. A round hood actually provides more physical protection to your lens than a petal-shaped hood does.
Skip Douglas
gool
Nov 07, 2007 06:49 |  #15
http://reviews.ebay.ca …0QQugidZ1000000​0003158880 (external link)
A list I came across on POTN.
Paul | 7D | 10D
Canon EF 85 f1.8| Tamron 17-50|Canon EF 35-80 (macro)| Tokina 11-16 | 580EX II
5 MDH | Kata 3N1-22 | Billingham 206 Presstop | Horusbennu NEO 1128TT + LX-1T
2,241 views & 0 likes for this thread, 13 members have posted to it.
1472 guests, 132 members online
