Thread started 08 Nov 2007 (Thursday) 03:21
B+W UV Filter Question...
tightlinez
Nov 08, 2007 03:21 |  #1
What’s the difference in B+W Multi-Resistant Coating vs. The Non-MRC ?
Is it worth pay the extra money for the MRC?
Jack
Canon 5D
BG-E4 Grip, EF 50mm f/1.4, EF 16-35mm f/2.8L, EF 24-70mm f/2.8L, EF 135mm f/1.2L, EF 70-200 f/2.8L, EF-S 10-22, EF 300mm f/4L, SpeedLite 580exII, Lowepro Computrekker AW, Lowepro Slinghot 300 AW
wimg
Nov 08, 2007 04:27 |  #2
tightlinez wrote in post #4275950 (external link)
In one word: yes.
The non-MRC is single-coated, and although it is a quality single coated filter, it can't beat a multi-coated filter, which is what you really, really want for digital.
HTH, kind regards, Wim
argyle
Nov 08, 2007 06:27 as a reply to  @ wimg's post |  #3
Ditto what Wim said...
Bushplane ­ Ken
Nov 08, 2007 09:18 |  #4
We all agree; if you are going to use a filter go for MRC.
Ken
Gear: A bunch of Canon stuff and a bunch of old Olympus 35 mm stuff (OM-1, OM-2, etc).
Double ­ Negative
*sniffles*
Nov 08, 2007 10:19 |  #5
Yep, get the MRC.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Indecent ­ Exposure
Nov 08, 2007 11:32 |  #6
MRC is the only option you should consider. Pretend they don't even offer a non-MRC.
- James -
www.feedthewant.com (external link)
500px (external link)
Gear List and Feedback
aoleg
Nov 09, 2007 00:20 |  #7
Some of the B+W non-MRC filters are multi-coated, and some are uncoated (yep, I've had a PL-TOP filter that was uncoated). I haven't heard about single-coated B+W's. Basically, MRC filters are much easier to clean because outer coating is "water-repellent". Considering the negligible price difference, I'd get the MRC.
5DmkII | Tokina 80-400 D | Tokina 100 2.8D macro | EF 85 1.8 | EF 70-200 4L | 24-70 2.8L
wimg
Nov 09, 2007 04:50 |  #8
aoleg wrote in post #4281941 (external link)
B+W's non-MRC filters are single coated, on both sides of the filter.
MRCs are multi-coated, and have the hardened water, grease and other substances repellant outer coating.
Kind regards, Wim
Double ­ Negative
*sniffles*
Nov 09, 2007 08:18 |  #9
I don't know, but I get a bit of a chuckle out of these "water repellent" coatings. It's a PIECE OF GLASS. Of course it's water repellent. ;)
I've never had a problem cleaning lens elements or filters (even "troublesome" Hoya and Cokin filters). I've been using the same stuff for 25 years; Formula MC and lens tissue.
wimg
Nov 09, 2007 08:40 |  #10
Double Negative wrote in post #4283067 (external link)
They are actually much easier to clean; they don't only repel water, but also grease and all kinds of other muck, plus the coating is scratch resistant to a rather large degree.
The owner of one of my preferred stores routinely shows off by using a water resistant marker on an MRC-coated filter vs a non-MRC one. The writing doesn't stick to the MRC coating, it does to the other one, and is rather hard to remove from the non-MRC filter.
Even so, the main reason to use it for me is the fact that it is multi- rather than single-coated.
Kind regards, Wim
Double ­ Negative
*sniffles*
Nov 09, 2007 08:48 |  #11
Interesting example, Wim. I'm sure the coating helps. I've never had a problem cleaning a filter so I guess I never noticed... Often enough though, I shoot in the rain and the filter definitely stays drier than the viewfinder!
Heliopan filters also offer this coating. From their brochure, "Dust and moisture repellent top coating on each side of the SH-PMC coated filters for easy cleaning and longest life."
But I agree though - the multi-coating is what counts.
1,240 views & 0 likes for this thread, 7 members have posted to it.
1465 guests, 173 members online
