Thread started 08 Nov 2007 (Thursday) 03:48
Is there a linear correlation between focal length and enlargement size?
Ephemeral
Nov 08, 2007 03:48 |  #1
I was just curious to know whether there was a linear correlation between focal length and magnification. That is to say, if I look through a lens at a square at focal length of 24mm and it is a 100 pixels wide, if I look at the same square at a focal length of 240mm, would the square take up 1000 pixels?
Canon 5D + Grip | 85mm L f/1.2 | 17-40mm L f/4.0 | [COLOR=Silver]24-70mm L f/2.8 |[COLOR=Black] 70-200mm f/2.8 L IS | Speedlite 580EX & 430EX | Manfrotto 190Pro + 488RC2
ephemeral.smugmug.com (external link)
Hermeto
Nov 08, 2007 04:00 |  #2
Of course not!
Focal length defines only the angle of view and nothing else.
Enlargement is something that you do (or don’t do) later, in post-processing.
On the sensor, they occupy exactly the same number of pixels.
Take a look here to compare different focal lengths and their corresponding angles of view.
http://www.tamroneurop​e.com/flc.htm (external link)
Ephemeral
Nov 08, 2007 04:25 as a reply to  @ Hermeto's post |  #3
Somehow I know that the answer was no, but I had to ask. :D
Hermeto
Nov 08, 2007 04:35 |  #4
It never hurts to ask, no problems with that!
I like this Tamron site..
It gives really nice visual presentation of focal lengths, angles of view and crop factor.
Banana ­ Tiger
Nov 08, 2007 05:00 as a reply to  @ Hermeto's post |  #5
Great site! I'm going to del.icio.us that one. Certainly helps with my lens buying decisions.
Canon 40d | Sigma 17-70 f/2.8-4.5 | Canon 85 f.18 | 430EX | Manfrotto 725b
SkipD
Joined Dec 2002
Nov 08, 2007 06:01 |  #6
Ephemeral wrote in post #4276026 (external link)
If you double the focal length of the lens on your camera, the linear dimensions of the image of a given subject (left-to-right or top-to-bottom) taken from the same position will double. If you compare the sizes of the image of a given subject (again, taken from the same position) taken with a 24mm lens and a 240mm lens, you will see a 10:1 difference in the linear dimensions of the image.
The dimensions I am referring to are at the film/sensor plane. If you enlarge each image equally (for example, make 4x6 inch prints from both images), you will see the same ratio of image sizes for the portion of the subject you are comparing.
Skip Douglas
Doug ­ Pardee
Nov 08, 2007 18:47 |  #7
Contrary to what some other folks have told you, the answer is "yes". Well, a qualified yes. (I assume that you're talking about shooting from the same distance.) There are some factors that tend to muddle the numbers a bit, so maybe you'd end up with 950 or 1050 pixels, but in round numbers the focal length is directly proportional to the magnification.
Also, if your square is 100 pixels when shot from 1000 feet with a 240mm lens, then it'll be about 1000 pixels when shot from 100 feet with that same lens.
RedHot
Nov 08, 2007 20:44 |  #8
It sounds like the OP might be talking about cropping that square since it takes up fewer pixels you'd be able to enlarge the square less than if the square filled more of your image.
Ephemeral
Nov 09, 2007 03:45 as a reply to  @ RedHot's post |  #9
Nope. Nothing to do with cropping.
If I didn't say pixels but said the width of the projected image of the square on the sensor, then is the answer yes?
This question came about because I was chatting to a friend about the 24-70 vs 24-105 and trying to work out how much more you'd get from the extra reach. I wasn't sure if the focal length was linearly correlated to the projected image size.
My thinking was, and I could be very wrong, if there was a correlation, then the difference you get in magnification of the projected image between 24mm to 59mm would be the same as from 70mm to 105mm. Then you'd get a good idea about the extra reach gained.
Mmmm...I should stick to just pressing the shutter button. It's much simpler. :p
StewartR
"your nose is too big"
Nov 09, 2007 04:27 |  #10
Hermeto is wrong. SkipD and Doug are right. The effect isn't quite linear - and is most non-linear for wide angles - but it's a reasonable approximation.
So, for example, a 400m lens will make an image on the sensor which is twice as large in each dimension (and therefore occupies four times as many pixels) as that produced by a 200mm lens.
However, the example you gave in your last post is incorrect. From 24mm to 59mm is a factor of 2.5, whereas from 70mm to 105mm is a factor of 1.5. The fact that 59-24 = 105-70 = 35 is irrelevant.
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
Ephemeral
Nov 09, 2007 05:48 as a reply to  @ StewartR's post |  #11
Oh. I see. It's not the actual focal length, it's the ratio between focal lengths.
SkipD
Joined Dec 2002
Nov 09, 2007 06:19 |  #12
Ephemeral wrote in post #4282610 (external link)
Precisely. Double the focal length and the linear dimension of the image doubles at the film/sensor plane.
As Stewart said, there may be some perceived differences when looking at the performance of the very wide-angle lenses. However, things in the middle of the wide-angle image will be doubled in width or height by doubling the focal length.
Skip Douglas
DrPablo
Nov 09, 2007 08:11 |  #13
Assuming the same aspect ratio, the angle of view of a given focal length will vary linearly with enlargement factor. The pixel count is a different story, because you can choose whether to hold pixel density (ppi) constant or not. If you hold ppi constant, then the number of pixels will change linearly with enlargement. If you keep the number of pixels the same, then the ppi wil change (inversely!) linearly with enlargement.
Canon 5D Mark IV, 24-105L II, 17 TS-E f/4L, MPE 65, Sigma 50 f/1.4, Sigma 85 f/1.4, 100 f/2.8L, 135 f/2L, 70-200 f/4L, 400 L
Film gear: Agfa 8x10, Cambo 4x5, Noblex 150, Hasselblad 500 C/M
SkipD
Joined Dec 2002
Nov 09, 2007 08:30 |  #14
DrPablo wrote in post #4283023 (external link)
I do not think that Ephermal is even thinking about the printing process ("enlargement"). I believe he was originally referring to the number of pixels (actually, sensor elements) in one direction that the image of a subject would cover on the sensor in the camera.
Skip Douglas
Hermeto
Nov 09, 2007 13:01 |  #15
SkipD wrote in post #4283113 (external link)
I guess, I misunderstood the question then..
2,436 views & 0 likes for this thread, 10 members have posted to it.
1508 guests, 130 members online
