Rotation of my Tiffin 67 mm circular polarizing filter, mounted on a Canon EFS 17-85 mm macro lens, does not always produce the desired results; namely, a uniformly darkened sky color (at the widest field of view under hazy atmospheric conditions). In some cases (apparently) I have not been able to find a filter rotation setting that avoids a color gradient; for example, from left to right. Assuming that I cannot re-orientate the line of vision 90 deg to the light source, or do not want to sacrifice field of view, are there any other technical fixes to this problem ?
Thanks for your reply.
