Thread started 09 Nov 2007 (Friday) 13:41
very weak at PP especially skin color
psxindo
Nov 09, 2007 13:41 |  #1
My pictures, after I'm done with PP, the skin color seems to be off. It doesn't look right to me. I only do basic PP, no skin smoothing, or bluring. just basic lightroom PP.
This is what I'm after.
5D mkIII | 5D mkII | 6D | EOS M | 16-35L | 24-70L | 70-200L 2.8 IS mkII | EF-M 22 | 50 1.4 | 85L | 100 2.8 macro | Tamron 17-50 2.8 | 2x 580 ex II | 580 ex | 2x sunpak 383 | 134GB CF |
Wishlist | 14L | 24L | 35L | 50L | 100L macro | 135L | 15 2.8 FE | 17L 4 TS | 45 2.8 TS | 90 2.8 TS |
psxindo
Nov 09, 2007 13:43 |  #2
sorry, the picture didn't attach, This is my friends and also my friend took the picture, I can't ask the photogs on how to PP it because he moved to another country.
psxindo
Nov 09, 2007 13:44 |  #3
these are my images
and
PixelMagic
Nov 09, 2007 14:19 |  #4
In Photoshop select a brush and set it to 0 percent Hardness, and Opacity to 2 or 3 percent. You can even turn on the Airbrush option if you desire.
In the Layers Palette create a blank new layer and set the layer Blend Mode to Darken
Now with your brush selected, hold down the ALT key to sample the desired skin tone. You will see the foreground color change.
Now paint with smooth even strokes over the areas you want to retouch. As you change locations resample the skin tone for that area.
When you're finished painting you can adjust the opacity of the layer to suit your taste.
psxindo
Nov 09, 2007 14:24 |  #5
how about just using lightroom... I have lots of pictures...
Can picture #1 be achieved using only lightroom?
PixelMagic
Nov 09, 2007 14:28 |  #6
Yes. You can certainly apply a vignette and make global adjustments with Lightroom and even set up presets to repeat the same "look" over a number of pictures. But for certain localized edits/adjustments, you need a program like Photoshop or Photoshop Elements.
831 views & 0 likes for this thread
Latest registered member is sandyn1024
626 guests, 234 members online
