lostdoggy wrote in post #4288060
If you looking to shoot the sky at night w/ a tripod then set lens to manual mode. Turn focus to infinite. Use MLU and use remote shutter release or timer. If you are shooting a subject within reasonable distance like 10ft or so then you can try using a laser pointer as a focus assist. If you have a ETTL flash like a 430 or 580 use can use the focus assist beam from the flash to help focus. After focus is obtained switch focus to manual and then turn off flash and then take picture.
Good advice.. but most(?) modern lenses will focus past infinity so you'll still need to focus on something in order to achieve infinity focus. You can instead focus on something very distant that's bright like a radio tower beacon, the moon, a far off street light, etc. You may be able to auto-focus on something very bright like the moon (some claim their lenses and camera are able to auto-focus on bright stars but YMMV) and then switch to manual focus or you can just manually focus (a right-angle viewfinder magnifier will help). The focus on some lenses can be easily moved so sometimes a wide rubber band or piece of tape is useful to keep the focus ring from accidentally moving.
When shooting the sky, you'll also want to stop down the lens a bit. Stars will bring out all of your lens' flaws so you'll want to minimize any possible CA and vignetting and increase sharpness by stopping down. I'd also recommend starting out with your widest lens unless you have something more specific in mind.
