I am aware of the prohibition against using canned compressed air.
However, I am wondering if it is ok to use it just before cleaning a sensor with pec pad and solution. The logic being this: it is advised to blow off the sensor the best you can before a cleaning to avoid the possibility of the swab dragging a piece of grit across the sensor and scratching it.
However, the pocket rockets just don't blast that well. If a blast of canned air can remove more grit, and if the swab cleaning will successfully remove any (canned air) residue from the sensor, and if the canned air will harm nothing else in the compartment, would it be advisable? /Dan
Now that i re-read it it does sound a bit naughty.
