-Flash OFF
-AF-Assist Beam OFF
-Picture quality set to "SuperFine"
-Picture size set to "M3" (1600x1200)
-Manual Shooting Mode
-No tripod/stable surface
Now comes the hard and redundant part, the ISO settings...
Bangalter Hatchling 8 posts Joined Oct 2007 More info | Nov 14, 2007 07:27 | #1 -Flash OFF
Nov 14, 2007 14:02 | #2 Also, while shooting under these light conditions, should I have "my colors" off? Or should I have it on "Tungsten", "Vivid", "Flourescent", "FluorescentH"?
_aravena isn't this answer a stickie yet? 12,458 posts Likes: 12 Joined Feb 2007 Location: Back in the 757 More info | Nov 15, 2007 22:22 | #3 That would depend on the lighting there... Last Shot Photography
ooo Goldmember 1,765 posts Joined Oct 2007 Location: NYC More info | Nov 17, 2007 03:27 | #4 Superfine and fine don't really make a difference. You can take pictures of both and take a look yourself. For low lighting exposures, I usually do Manual, colors vivid, white balance - tungsten or flourescent (depends on lighting), iso 400 (that is because I don't like the noise). If you don't mind the noise turn the iso to high. Like people said this camera isn't really meant for something like this, unless its a small concert and your up close.
Collin85 Cream of the Crop 8,164 posts Joined Jan 2007 Location: Sydney/Beijing More info | Nov 17, 2007 05:47 | #5 If the lighting is bad, you're gonna have to really notch up that ISO. This camera wasn't really designed for this kind of thing.. even dSLRs often have trouble nailing it without resorting to high ISOs and a 'fast' (high maximum aperture) lens. Col | Flickr
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Nov 20, 2007 17:06 | #6 High ISO. Usually the lighting will be tungsten. Set for that anyhow, rather than fluorescent or Auto unless you know there are fluorescent lights. In any case, if the lights are gelled, white balance will go crazy trying to adjust for the gelled lights, so you want a set WB which will let the colours come through. Jon
| Latest registered member was a spammer, and banned as such! 2296 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
