FORUMS Forum FAQ and Information Forum Talk
Thread started 17 Nov 2007 (Saturday) 01:39
Subscription problem
Olli
-Mighty Mod-
Gallery: 21 photos
Nov 17, 2007 01:39 |  #1
When I click "Subscribed Threads" under "Quick Links", why a page showing this message opens, and not the list of subscribed threads?
|| # vBulletin 3.6.7 PL1
|| # Copyright ©2000-2007 Jelsoft Enterprises Ltd. All Rights Reserved. ||
|| # This file may not be redistributed in whole or significant part. # ||
|| # --------------- VBULLETIN IS NOT FREE SOFTWARE --------------- # ||
|| # http://www.vbulletin.c​om (external link) | http://www.vbulletin.c​om/license.html (external link) # ||
// vB_AJAX_NameSuggest
* Class to read input and suggest usernames from the typed fragment
* @param string Name of variable instantiating this class
* @param string ID of the text input element to monitor
* @param string Unique key of the popup menu in which to show suggestions
function vB_AJAX_NameSuggest(va​rname, textobjid, menukey)
var webkit_version = userAgent.match(/apple​webkit\/([0-9]+)/);
if (AJAX_Compatible && !(is_saf && !(webkit_version[1] >= 412)))
this.menuobj = fetch_object(menukey + '_menu');
this.textobj = fetch_object(textobjid​);
this.textobj.onfocus = function(e) { this.obj.active = true; };
this.textobj.onblur = function(e) { this.obj.active = false; };
this.textobj.obj = this;
* Varaiables used by this class
* @var string The name given to the instance of this class
* @var string The menu key for the vbmenu name suggestion popup
* @var string The current name fragment text
* @var string The current string of completed names (Foo ; Bar etc.)
* @var integer The currently selected name index in the menu
* @var boolean Is the suggestion menu open or not
* @var object A javascript timeout marker
* @var array The list of suggested names
* @var object The XML sender object
* @var boolean True when text box is focussed - only show menu when true
this.varname = varname;
this.menukey = menukey;
this.fragment = '';
this.donenames = '';
this.selected = 0;
this.menuopen = false;
this.timeout = null;
this.names = new Array();
this.xml_sender = null;
this.active = false;
* Options used by this class
* @var boolean Allow multiple names (Foo ; Bar etc.) or just single (Foo)
* @var integer The minimum length of the text fragment before requesting a search
this.allow_multiple = false;
this.min_chars = 3;
// vB_AJAX_NameSuggest methods
* Reads the contents of the text input box
this.get_text = function()
if (this.allow_multiple)
// search for a semi-colon (meaning we have more than one name in the box)
var semicolon = this.textobj.value.las​tIndexOf(';');
if (semicolon == -1)
// the current name is the only one in the text box
this.donenames = new String('');
this.fragment = new String(this.textobj.va​lue);
else
// also need to store completed names in the text box
this.donenames = new String(this.textobj.va​lue.substring(0, semicolon + 1));
this.fragment = new String(this.textobj.va​lue.substring(semicolo​n + 1));
else
// trim away leading and trailing spaces from the fragment
this.fragment = PHP.trim(this.fragment​);
* Sets the contents of the text input box
* @param integer The index of the desired name in this.names to insert
this.set_text = function(i)
this.textobj.value = PHP.ltrim(this.donenam​es + " " + PHP.unhtmlspecialchars​(this.names[I]) + " ; ");
else
this.textobj.value = PHP.unhtmlspecialchars​(this.names[I]);
this.textobj.focus();
this.menu_hide();
return false;
* Moves the 'selected' row in the menu
* @param integer Increment (1, -1 etc.)
this.move_row_selectio​n = function(increment)
var newval = parseInt(this.selected​, 10) + parseInt(increment, 10);
if (newval < 0)
newval = this.names.length - 1;
else if (newval >= this.names.length)
newval = 0;
this.set_row_selection​(newval);
return false;
* Sets the 'selected' row in the menu
* @param integer The index of the desired selection (0 - n)
this.set_row_selection = function(i)
var tds = fetch_tags(this.menuob​j, 'td');
tds[this.selected].cla​ssName = 'vbmenu_option';
this.selected = i;
tds[this.selected].cla​ssName = 'vbmenu_hilite';
* Event handler for the text input box key-up event
* @param event The event object
this.key_event_handler = function(evt)
evt = evt ? evt : window.event;
if (this.menuopen)
// 38 = up
// 40 = down
// 13 = return
// 27 = escape
switch (evt.keyCode)
case 38: // arrow up
this.move_row_selectio​n(-1);
return false;
case 40: // arrow down
this.move_row_selectio​n(1);
return false;
case 27: // escape
this.menu_hide();
return false;
case 13: // return / enter
this.set_text(this.sel​ected);
return false;
// create the fragment
this.get_text();
if (this.fragment.length >= this.min_chars)
clearTimeout(this.time​out);
this.timeout = setTimeout(this.varnam​e + '.name_search();', 500);
else
this.menu_hide();
* Sends the fragment to search the database
this.name_search = function()
if (this.active)
if (!this.xml_sender)
this.xml_sender = new vB_AJAX_Handler(true);
this.xml_sender.onread​ystatechange(this.onre​adystatechange);
this.xml_sender.send('​ajax.php?do=usersearch​', 'do=usersearch&fragmen​t=' + PHP.urlencode(this.fra​gment));
var me = this;
* OnReadyStateChange callback. Uses a closure to keep state.
* Remember to use 'me' instead of 'this' inside this function!
this.onreadystatechang​e = function()
if (me.xml_sender.handler​.readyState == 4 && me.xml_sender.handler.​status == 200 && me.xml_sender.handler.​responseXML)
var users = fetch_tags(me.xml_send​er.handler.responseXML​, 'user');
for (i = 0; i < users.length; i++)
me.names[I] = me.xml_sender.fetch_da​ta(users[I]);
if (me.names.length > 0)
me.menu_build();
me.menu_show();
else
me.menu_hide();
me.xml_sender.handler.​abort();
* Builds the menu html from the list of found names
this.menu_build = function()
this.menu_empty();
var re = new RegExp('^(' + PHP.preg_quote(this.fr​agment) + ')', "i");
var table = document.createElement​('table');
table.cellPadding = 4;
table.cellSpacing = 1;
table.border = 0;
for (i in this.names)
var td = table.insertRow(-1).insertCell(-1);
td.className = (i == this.selected ? 'vbmenu_hilite' : 'vbmenu_option');
td.title = 'nohilite';
td.innerHTML = '<a onclick="return ' + this.varname + '.set_text(' + i + ')">' + this.names[I].replace(​re, '<strong>$1</strong>') + '</a>';
this.menuobj.appendChi​ld(table);
if (this.vbmenu == null)
if (typeof(vBmenu.menus[t​his.menukey]) != 'undefined')
this.vbmenu = vBmenu.menus[this.menu​key];
else
this.vbmenu = vBmenu.register(this.m​enukey, true);
else
this.vbmenu.init_menu_​contents();
* Empties the menu of all names
this.menu_empty = function()
this.selected = 0;
while (this.menuobj.firstChi​ld)
this.menuobj.removeChi​ld(this.menuobj.firstC​hild);
* Shows the menu
this.menu_show = function()
if (this.active)
this.vbmenu.show(fetch​_object(this.menukey), this.menuopen);
this.menuopen = true;
* Hides the menu
this.menu_hide = function()
try
this.vbmenu.hide();
catch(e) {}
this.textobj.onkeyup = function(e) { return this.obj.key_event_han​dler(e); };
this.textobj.onkeypres​s = function(e)
e = e ? e : window.event;
if (e.keyCode == 13)
return (this.obj.menuopen ? false : true);
|| # Downloaded: 06:34, Sun Jul 8th 2007
|| # CVS: $RCSfile$ - $Revision: 15546 $
My Instagrams (external link)
"The best travel is a leap in the dark. If the destination were familiar and friendly what would be the point in going there?" (Paul Theroux: Dark Star Safari)
Image Posting Rules
Skip ­ Souza
Location: The Left Coast in the Land of Fruits and Nuts
Nov 17, 2007 02:05 |  #2
Wow :shock:
Haven't seen that before. Have you tried clearing your cache/temp files?
Bless the recently fallen and their family and friends.
I have a Cannon with me at all times. You can't take the shot if you don't have something with which to shoot. :rolleyes:
That which does not kill me ~~ Should Run.
5DMkII, 7D, 70-300L IS, 24-105L,
No more PayPal gift payment requests.
"PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED."
condyk
Africa's #1 Tour Guide
Nov 17, 2007 02:12 |  #3
Looks like you caught Pekka with his pants down :confused:;)
https://photography-on-the.net …/showthread.php​?t=1203740
Olli
-Mighty Mod-
Gallery: 21 photos
Nov 17, 2007 02:37 |  #4
Skip Souza wrote in post #4331303 (external link)
Wow :shock:
Thanks Skip. Cache cleared and now works ... simple when you know it.
Image Posting Rules
Skip ­ Souza
Nov 17, 2007 02:58 |  #5
It was just luck. In fact it is my first answer when something really weird jumps up. It can't hurt and has about a 50% success rate ;-)a
::John::
Gallery: 60 photos
Nov 17, 2007 04:13 |  #6
condyk wrote in post #4331313 (external link)
Thanks - I needed a laugh!
I am the proud owner of the Peleng 8mm Fisheye lens
1,608 views & 0 likes for this thread, 4 members have posted to it.
1060 guests, 102 members online
