Thread started 17 Nov 2007 (Saturday) 09:44
Is the canon st-e2 the only way to keep ettl?
John ­ E
Nov 17, 2007 09:44 |  #1
I'm a newbie to off camera flash lighting and am contemplating buying the st-e2 to control my 580 EX II and my 430 EX off camera. I understand it's infrared and not radio and so it has it's line of sight limitations. However, do all radio transmitters lose ettl and force you to go manual on your flash? If that is the case do you need a separate light meter? So the main benefit with radio is the increased distance but the disadvantage is losing ettl? Why doesn't canon come out with their own radio transmitter with ettl?
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
Mark-B
Nov 17, 2007 11:22 |  #2
Your options for off camera ETTL are the ST-E2, an off shoe cord, or another flash. You could probably get a used 550EX for not much more money than the ST-E2. You would have the advantage of a fill light on camera and greater range than the ST-E2.
I don't know why Canon hasn't done it, but someone else has come up with a solution. Radio Popper (external link) is a new device that attaches to your existing 580EX, 550EX, or ST-E2 transmitter and converts the light signal to a radio signal. This allows you to have the convenience of ETTL but without the line of site and range limitations of the master flash.
Mark-B
msbphoto.comexternal link
Franko515
"doped up on pills"
Nov 17, 2007 11:54 as a reply to  @ Mark-B's post |  #3
^^^^^^^^^^^Excellent reply^^^^^^^^^^^^^^^De​ad On^^^^^^^^^^
Light, composition, shooting technique matter to the end quality most. -Pekka
My Flickr Gallery (external link)
My Gear List
nadtz
Nov 17, 2007 14:15 |  #4
Be aware the radio poppers dont actually exist yet (at least as far as the public is concerned) but hopefully will be available soonish.
As for why canon/nikon/everyone else doesnt do radio instead of 'IR', its so they dont have to deal with the FCC and FCC like entities around the world, hopefully this will change now that there are global radio standards
Rudeofus
Nov 19, 2007 11:43 |  #5
nadtz wrote in post #4333656 (external link)
It may also have to do with the fact that triggering a flash via RF has been patented by pocket wizard in 1994. Yes, you do get a few alternatives, but they're either directly from China (where US patents don't apply), or they don't use a CPU in the flash side unit (thereby circumventing the patent but achieving inferior performance).
Discovery is not accidental. We discover only when we make ourselves ready to receive and photographers seek discovery by mastering their craft. But it begins somewhere else. It begins with daisies, kids, awful scenes, falling in love, or growing old. It begins with that which matters to you. And it ends with visual statements that express what matters to you about these things. It is not sight the camera satisfies so thoroughly, but the mind. - Christian Molidor
rhys
Dis-Membered
Nov 19, 2007 13:35 |  #6
the Chinese stuff doesn't work anyway. I have a Chinese set and am trying to get my money back on it all.
The STE-2 or another 580EX are the only two ways of firing Canon flashes remotely. They do retain full ETTL2. The radio-popper is an interesting idea unlikely to come to fruition.
Rhys
The empire conquers yet more galaxies:
www.sageworld.co.uk (external link)
www.sageworld.org (external link)
www.sagephotoworld.com (external link)
Blog: http://360.yahoo.com/t​hunderintheheavens (external link)
Free cheese comes only in mousetraps
bacchanal
Nov 19, 2007 13:40 |  #7
rhys wrote in post #4346130 (external link)
It doesn't work for you, you mean. They aren't 100% reliable by any means, but they are about 10% the cost of PW's.
bieber
Nov 19, 2007 13:48 |  #8
Or, you know, Pocket Wizards ;) And I don't see any reason Radio Popper is unlikely to come to fruition; they've finalized the design, and plan to go to production soon...
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
rhys
Dis-Membered
Nov 19, 2007 16:02 |  #9
bieber wrote in post #4346225 (external link)
There's many a slip betwixt cup and mouth. The Foveon sensor was due to be mass-produced as a 1.3mp insert for existing SLRs some years ago. Thus far only Sigma uses the Foveon sensor. The SLR conversion was due to go into production imminently too - never happened.
I hear Pocket Wizards work. I hear ebay gadgets work. The fact is I have never tried pocket wizards and I found from personal experience ebay gadgets do not work.
I have the STE-2 now so the matter is entirely academic anyway.
Rhys
fortinaa
Nov 19, 2007 16:44 as a reply to  @ rhys's post |  #10
Just to chime in... I tried the ebay units as well. The range was horrible. They wouldn't trigger a light from one side of my basement to the other (say 25ft) without obstructions in the way. I've tested PW from the other side of the house and around corners without any hiccups whatsoever.
For the OP, your cheapest (good) route is to get another flash like a 550ex. As others have mentioned, cost won't be much more than an ST-E2. Plus, you can use easily found rechargables in it, where the Transmitter requires a special battery. Hope you always have a spare if it dies during a shoot. Plus, a 3rd flash gives you the option to use it as a background, hair, or rim light for more creativity.
Aaron
zwollenaar
Gallery: 14 photos
Nov 19, 2007 17:02 as a reply to  @ fortinaa's post |  #11
Looks like 550 is discontinued, would a 430EX be a replacement?
fortinaa
Nov 19, 2007 17:24 as a reply to  @ zwollenaar's post |  #12
Yes, you can use a 430ex as well, but it is lower power. The 430ex should be in the same price range as buying a used 550 if you can find one. Otherwise, the 580exII is the current replacement for the 550ex.
Aaron
DaveG
Joined Aug 2003
Nov 19, 2007 21:06 |  #13
John E wrote in post #4332414 (external link)
Why don't you just use your 580 and 430 within the Canon wireless system? You don't need another thing.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
Dropbear
Nov 20, 2007 00:54 as a reply to  @ DaveG's post |  #14
what rubbish.. for something that 'doesn't work' - a lot of people are very happy with it's performance.. :rolleyes:
Ian Williams
Model Mayhem (external link) | Flickr (external link) | FACEBOOK (external link)
Big ­ WIll
"Slight breach of etiquette"
Nov 20, 2007 06:54 |  #15
Love the little ones i got off eBay! Work good. The odd time they don't fire. However worth it for only £20ish :)
Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutterhttp://www.photography​-on-the.net …p?p=1606920&pos​tcount=132
3,968 views & 0 likes for this thread, 15 members have posted to it.
500 guests, 126 members online
