Thread started 19 Nov 2007 (Monday) 00:37
How to set it up
bmynbr
Nov 19, 2007 00:37 |  #1
Ok, so I will be getting my 580 ex2in the next few days:lol:, and I have access to two more whenever I need them. I figure I could learn alot about flash photography with this, just need a decent starting point.
I was thinking one to the right, slightly above head level,
one to the left for fill, and one as a hair light.
Basically I was wondering if this is how you guys would position the flashes, and what power ratios you would have them at.
Thanks in advance,
Dave
Canon 7d, 50 f1.8, Canon 17-85is usm, 58mm hoya cpl, 67mm b&w slim cpl, Manfrotto 190 tripod with 486rc2 ball head, Canon efs 10-22, 580exII, cybersyncs, Canon 70-200 f4L
http://www.treklens.co​m/members/BMYNBR/photo​s/ (external link)
bmynbr
Nov 19, 2007 00:53 |  #2
Oh ya, one more thing, I have an off shoe cord which I am going to extend to the main flash.
Dermit
Joined Nov 2005
Nov 19, 2007 07:52 |  #3
I use a 580EX and a 550EX all the time for simple single person, or sometimes two people portraiture on location. I use the built in wireless master/slave features that the flashes have. I put one flash up on a bracket on camera centered above the lens. I put the other on a stand and the location of it depends on the positioning of the subject and the look I want. But it typically is placed anywhere from 45 to 90 degrees from my/camera position. I sometimes shoot this off camera light into or through an umbrella. But the off camera light on the stand is the one I use for the main light and the one above camera is the fill.
I start by setting both to equal power (1:1 ratio) and adjust the amount of light falling on the subject by adjusting the distance of light to subject. I look at the image on LCD and if it is not what I want in ratio then I either adjust lighting distances or the ratios on the Canon system.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
jr_senator
Nov 19, 2007 08:58 |  #4
bmynbr wrote in post #4343150 (external link)
...one to the right, slightly above head level,
The one to the right should be close to the camera and the one to the left should be 30-35 degrees offset (no more than 45 degrees). This is where I like using a flash meter.
bmynbr
Nov 19, 2007 14:23 |  #5
Thanks for the info, should I use a third for a hairlighth or backdrop light. And can it also be triggered as a slave.
Thanks again, Dave
jr_senator
Nov 19, 2007 18:50 |  #6
You may want something like this, http://www.bhphotovide​o.com …miQuest_LQ891D_​Snoot.html (external link)
1,675 views & 0 likes for this thread, 3 members have posted to it.
How to set it up
651 guests, 117 members online
