Thread started 21 Nov 2007 (Wednesday) 08:21
Strobist question: combining 580EX/430EX with lower-cost unit
Stephan.
Nov 21, 2007 08:21 |  #1
Hi,
is it possible/would it make sense to use a Canon flash like the 580 EX II or the 430 EX in conjunction with a lower-cost unit like a Vivitar?
I'd really like to have a Canon flash for possible on-camera use and combine it with a second flash for those Strobist-style setups. However I'm a bit put off by the pricetag of buying two Canon units.
Any recommendations?
The flashes are supposed to be linked using a wired connection (for starters) to a 40D. If you have an idea how to do that, please bring that hint forward too ;-)a
Thanks!
cdifoto
Don't get pissy with me
Nov 21, 2007 08:26 |  #2
Manually, no big deal! This is a Sunpak 383 Super & 580EX:
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i14.photobucket​.com …difoto/2007-11-15-033.jpg (external link)
Curtis ­ N
Master Flasher
Nov 21, 2007 08:28 |  #3
The cheapest way to go about that is to use an optical slave on the off-camera flash. The EX Speedlite on-camera will trigger it. Speedlite must be used in manual flash mode. It works good indoors but not outdoors.
Option 2: A PC cord plugged into your camera's PC socket for the off-camera flash. May require a hotshoe adapter for the flash, depending on what you end up with. Your camera's PC socket and hotshoe can be used simultaneously. You can still use E-TTL with the hotshoe flash this way.
More details in this thread:
https://photography-on-the.net/forum/showthre​ad.php?t=308108
Stephan.
Nov 21, 2007 08:38 |  #4
Thanks guys. I'm really happy to hear that it's possible.
I think I like Curtis' 2nd idea best since I was planning on using it a lot outdoors.
Maybe that's silly, but I would also be able to use some kind of hotshoe extension cable for the Canon flash so I can basically have two flashes which can be used off-camera and moved independently (well, as much as the cable allows), right?!
Cdifoto, that picture of yours looks great. Very comforting to see that is can be done!!
Curtis N, do you have a new avatar? I remember from browsing through the forum that you used to have a photo of yourself (?) and a flash, is that right?
Curtis ­ N
Master Flasher
Nov 21, 2007 08:41 |  #5
Stephan. wrote in post #4358237 (external link)
Yes. I'll probably change it back after a while. It sort of goes along with the quote in my sig to complete the joke. ;)
Stephan.
Nov 21, 2007 08:44 |  #6
Oh well, now that you mention it I see the connection. I oversaw your new signature before.
Are there any issues with the "sync voltage" (?) regarding the less expensive flash on the PC port? (I didn't quite get this whole concept of sync voltage). However, I'd like to be sure that the flashes doesn't damage the camera.
I really liked your old avatar. And hey, I also got some good-looking girls (hopefully you like them) in my avatar, now that you bring up that topic :-)
Stephan.
Nov 21, 2007 08:45 |  #7
cdifoto wrote in post #4358264 (external link)
You better change it. I'm starting to develop a crush on you. :rolleyes: :lol:
That's funny!!
cdifoto
Nov 21, 2007 08:46 |  #8
Stephan. wrote in post #4358272 (external link)
Some of the really old Vivitars are debatable or even a no-go, but the new Sunpak 383s and Vivitar 285s (only $80-90 brand new at B&H) are perfectly safe. There are many perfectly fine older ones but if I was buying a few of those I'd keep them away from my hot shoe and just use 'em on a light stand...or at least invest in a voltage meter and test 'em first.
Stephan.
Nov 21, 2007 08:47 |  #9
And Curtis, that's a great thread you got there! Thanks a lot!
Stephan.
Nov 21, 2007 08:49 |  #10
Great, thanks cdifoto!
Alright, I'll get one of those and combine it with either the 580 or 430. Tough decision, eh, but that's another story I guess :-)
cdifoto
Nov 21, 2007 08:51 |  #11
I went with the Sunpak 383. Brand new for 80 bucks, similar power as the 580EX, and the head swivels AND bounces. The Vivitar only bounces but it zooms while the Sunpak has a fixed 35mm AOC head. No big deal really because usually I'm either bouncing it or shooting it into an umbrella.
Stephan.
Nov 21, 2007 09:02 |  #12
Thanks cdifoto!
Curtis ­ N
Master Flasher
Nov 21, 2007 09:16 |  #13
I'll change the Avatar back someday, and I'll use this quote in my sig! :lol:
To the OP: Here's a link with more info about trigger voltage. You should be ok up to 250v on the PC socket.
http://www.botzilla.co​m/photo/strobeVolts.ht​ml (external link)
cdifoto
Nov 21, 2007 09:29 |  #14
Curtis N wrote in post #4358428 (external link)
I never said that. You and Stephan need to quit making things up! :rolleyes: :D
Stephan.
Nov 21, 2007 13:22 |  #15
That quote would be hilarious :-)
2,407 views & 0 likes for this thread
Latest registered member is icon-photo
731 guests, 276 members online
