Thread started 27 Aug 2004 (Friday) 09:27
Can filters ruin the quality of an image?
Rebel
Joined Aug 2004
Aug 27, 2004 09:27 |  #1
I just bought the 70-200L f/4. I added a polarizer just the other day. I shot some cars this afternoon (first shoot with the polarizer on) and the picture quality seems about as good as my cheapest lens. Can this mean I bought a bad filter? Its a COKIN circular polarizer 67mm
Belmondo
Joined Jul 2003
Aug 27, 2004 09:39 |  #2
You'll lose some lens speed with a CP filter, and you might kill some of the highlights. Whether or not it is the problem with your photos is hard to say. I use a CP only when I need a CP. Otherwise, I use UV or daylight filter, and only for lens protection.
I'm not short. I'm concentrated awesome!
nucki
Joined Apr 2003
Aug 27, 2004 09:51 |  #3
well, I heard that the cokin polarizers are'nt good. but thats only what I heard. Have you tried a normal "screw on" CP?
Peter
Rebel
Joined Aug 2004
Aug 27, 2004 10:25 |  #4
Yeah, its a screw in type. I only use it to remove the glare of the windscreen and reduce reflections in the car's paintwork. I was shooting at about 1/40 - 1/60 handheld with the ISO right down to 100 on a very diffused overcast day. I seemed to have lost all detail. I would have liked to post an image, but I was so upset that I deleted them all first.
IncompletePete
Joined Aug 2004
Aug 27, 2004 10:27 |  #5
I use a Jessops own screw in CP filter, its pretty good quality, got some nice results from it!
www.sportsshooter.com/​pete (external link)
www.petelorence.com (external link)
John_T
Gallery: 127 photos
Joined Jun 2003
Aug 27, 2004 10:39 |  #6
I would say " I was shooting at about 1/40 - 1/60 handheld with the ISO right down to 100 on a very diffused overcast day." would have more to do with it than anything else. :wink:
Canon : EOS R : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : RF-24-105L IS : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
Muffin ­ Princess
Joined Aug 2004
Aug 27, 2004 11:32 |  #7
Shooting handheld at aht speed, yeah, I would say you'd lose some details, you'd probably need a faster shutter to really get some good details.
I mainly use a CP for bringing out the blues in the sky and such like, makes it look a lot deeper and warmer! :)
Canon 40D, Canon 24-70 f/2.8 L, Canon 70-200 f/2.8 L IS, Canon 50mm f/1.8, Canon Speedlite 430EX
www.eclipseimages.co.u​k (external link), Twitter: @eclipse_images (external link)
Facebook: www.facebook.com/eclip​seimages (external link)
Trekking for WSPA: Sponsorship page (external link)
timmyquest
Joined Dec 2003
Aug 27, 2004 12:08 |  #8
What he said, thats much too slow for that lens.
Capturing life a fraction of a second at a time
Tapeman
Sliced Bread
Joined Jan 2004
Aug 27, 2004 18:23 |  #9
I have circular polarizers that cost more than many lenses. Good 77mm filters are not cheap. Hopefully you will have multiple lenses that you can use them on.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Rebel
Joined Aug 2004
Aug 27, 2004 20:56 |  #10
Thanks for all your advice, I really do appreciate it. I think you maybe right about the speed. I always thought that overcast conditions were ideal for shooting cars. Am I terribly mistaken?
Aylwin
Joined Aug 2003
Aug 27, 2004 21:16 |  #11
No, I don't believe you are mistaken. It's the CP that's the problem. It requires you to use the slower speed. Besides, on an overcast day I don't think you need it much. Simply removing it would give you maybe 2 stops. Then there's ISO100. You could easily use ISO200-400 to allow for another stop or two. That should bring your shutter speed up to around 1/180.
Aylwin
5D MkII, a few lenses, and some other bits and bobs
John_T
Gallery: 127 photos
Joined Jun 2003
Aug 28, 2004 01:13 |  #12
These were made outdoors on a bright hazy day at around 1/100s @ f2.8 and no filters. I worked more with angles that gave reflections I wanted and avoided blow outs.
Cadwell
Joined Jan 2004
Aug 28, 2004 01:46 |  #13
OK, there are probably two factors at work here;
1. (as has been mentioned) you probably needed to use a higher shutter speed unless you have very steady hands. Remember the old rule that the shutter speed for hand holding should be (as a minimum) the inverse of the focal length and don't forget the crop/multiplier factor. So for 70mm you need @ 1/100th or faster and for 200mm you need 1/320th or faster.
2. Quality of the polariser. There is absolutley no point in putting a cheap polariser (or indeed any other kind of filter) on a good lens. If you do that, you may as well have just bought cheap glass in the first place.
As to the other points, I don't think that overcast is necessarily better for car photography. Even lighting is the key.
Polarisers are wonderful devices for car photography. Used properly they can turn the glass transparent and minimise unwanted reflections allowing you to see the detail of the cars. Stick one on the front of the lens and then twiddle away until you get a result you are pleased with through the viewfinder. KennyG did a great example post on this subject a few months ago.
For some examples of my own http://2004.ukmotorspo​rtpics.com/c215223_1.h​tml (external link) all of those static car shots on the first page were taken in awkward early morning light using an EF 17-40mm f/4.0L and a Hoya 77mm Super HMC-Pro1 Circular Polariser. Whilst by no means perfect, I wouldn't have got them without the polariser.
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
toddb
Joined Jul 2003
Aug 28, 2004 10:52 |  #14
Oh man, I thought I just had this figured out. I thought the crop factor only meant to show what equivalent frame filled picture and that the image is actually the same, except since the sensor is smaller then 35mm film that only a "cropped" part of the image coming through is recorded. In another thread I thought it was explained to me this way and therefore the DOF calculations are not with the added crop factor but of what the lens actually is. Wouldn't this be true for the inverse focal length rule as well? I mean it's the same image and distance coming through the lens as it would on a 35mm format, just cropped. I would like to know, I'm not saying your wrong since I don't know for sure.
10D, EF17-40L, EF50F1.4, EF28-135IS, 550EX [AlienBees 2xB800 and 1xB400 with large softbox and reversible umbrella] Sekonic L-358
Cadwell
Joined Jan 2004
Aug 28, 2004 11:21 |  #15
No, I think you still have it figured right. The inverse focal length rule really relates to the Field of View which of course narrows with longer focal lengths. The narrower the Field of View, the more apparent vibration from hand holding becomes. The crop factor has the effect of narrowing the field of view so it needs to be taken into account in the calculation.
Glenn
2,873 views & 0 likes for this thread, 14 members have posted to it.
1748 guests, 132 members online
