Thread started 27 Aug 2004 (Friday) 10:53
new pictures for critique
saddlepotatoe
Joined May 2004
Aug 27, 2004 10:53 |  #1
HTTP response: 400 | MIME changed to 'text/html'
I'm pretty new to this photography thing so it would be greatly appreciated if you gave me some tips to improve my photography skills thanks
Molydood
Joined Aug 2004
Aug 27, 2004 15:24 |  #2
number one looks a little washed out to me
number two is great if a little wonky, maybe try the old rule of thirds on it too for improvement, as you have the horizon bang in the centre
number 3 is sepia, and is not my thing.
im new also, so dont take these comments too serisouly :-)
My real name is Martin
20D (FS 300D), fifty, 18-55, 70-200 f4, tubes
tofuboy
Joined Aug 2004
Aug 27, 2004 15:36 |  #3
I would say work on your composition a bit. 'Rule' of thirds as mentioned by Molydood.
Image 1 could probably be touched up a bit in PS to get rid of the 'washed out' look by adjusting the levels and/or curves.
Image 2 looks like beautiful scenery, but like Molydood said, rule of thirds probably would have made this photo a bit nicer with respect to the horizon line. The top third or so of the image is dead sky and doesn't add anything to the image.
Image 3 doesn't do too much for me. The main subject is smack in the middle of the picture pretty much. I think rule of thirds could have helped this one a bit too.
Nice shots and keep up the good work :)
-Matt Seattle Photography - Nature|Portrait|Event (external link)
'The negative is comparable to the composer’s score and the print to its performance.' - Ansel Adams
Sailor ­ Don
Joined Jul 2004
Aug 28, 2004 06:13 |  #4
Second photo is nice. My opinion is that it would be improved with a landscape orientation and appropriate cropping.
Sailor Don
flowe
Joined Mar 2003
Aug 28, 2004 09:14 |  #5
As you are new to photography, it's probably not too late to mention that calm water and sea horizon always are horizontal and mirror images on calm water always are exactly vertically below the real thing. To me, even small deviations are obvious and make me loose interest.
Every editor allows to rotate an image by degrees and fractions - and then to crop it. But don't do it in increments - always undo first and select a more likely amount until it's ok. Sharpen last.
A very handy tool is the freeware Screen Ruler (external link). Just unzip the file, put it in a folder, make a link to the desktop and preferably the task bar and start it - no installation process, all Windows. SR can be moved with the mouse or the arrow keys, and swivelled to vertical to check on mirror images or items such as building edges or trees etc. You can have as many SR on screen as required - very useful for assessing cropping etc.
It's hard work, but very rewarding! :D :D
Apart from the running out sea, the sunset to me has some merits!
Big_B
Honorary Moderator
Joined Jun 2004
Aug 28, 2004 11:22 |  #6
Agree with previous comments about #1. #2 will be improved with the above suggestions. However, don't get too disheartened - it's a pretty good picture just as it is! :)
www.pbase.com/sam_blac​kie (external link)
1,711 views & 0 likes for this thread, 6 members have posted to it.
997 guests, 101 members online
