Thread started 23 Nov 2007 (Friday) 19:08
Attempt with White seamless
pamijo89
Nov 23, 2007 19:08 |  #1
Please let me know what you think.
Canon 20D (with grip), Canon 40d, Canon L 24-70mm,Canon 50mm 1.4, Canon 85mm 1.8, 70-200mm 2.8 L, 580 ex speedflash, 2 AB800, 2 softboxes, 4 strobes, backdrops, flash bracket, reflectors and other misc....
Federkeil
Nov 23, 2007 20:25 |  #2
I like the exposure in the first picture and the expressions but I don't really care for the compsition. I love the second picture, but it's a little overexposed for my taste. Better than I can do!
Curtis ­ N
Master Flasher
Nov 23, 2007 20:46 |  #3
Yeah #1 is a touch overexposed. This can be corrected in PP easily enough.
You're getting some light reflecting off the backdrop and bleeding onto the edges of the subjects. Try to keep some distance between subject and background and don't blast more light on it than necessary. A white backdrop only needs to be about 1 stop brighter than the subject to keep it pure.
TMR ­ Design
Joined Feb 2006
Nov 23, 2007 22:11 |  #4
Curtis N wrote in post #4373366 (external link)
Yes but lets be clear about how the metering is done. If you are taking incident readings from the background then 1 stop would do it. If you are taking reflective spot readings (which can be done from camera or subject position without walking up to your background) then you need to be 3 stops over the incident subject exposure to achieve white and 1/3 stop over that will get you to white with no detail but you must watch clipping and the return from the background to the subject area.
Robert
Curtis ­ N
Master Flasher
Nov 23, 2007 23:46 |  #5
I was going to type all that but I was too lazy and I knew you'd come in and clear things up. :D
1,395 views & 0 likes for this thread, 4 members have posted to it.
1003 guests, 107 members online
