How can shortened or even eliminate long elapse time when doing long/time exposure. Camera Canon 5D. If this can be done, will it increase the noise?
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | Nov 24, 2007 10:33 | #1 How can shortened or even eliminate long elapse time when doing long/time exposure. Camera Canon 5D. If this can be done, will it increase the noise? www.eaglesnestphotography.com
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Nov 24, 2007 10:36 | #2 If you have long exposure noise reduction turned on, the camera will take as long to process the shot as it does to take it. Turning it off will increase noise, but if you make a blank exposure of the same duration you can mask it against the original exposure in PP to get much the same result. Jon
Wow Jon, that was fast! thank you for your prompt response. BTW, what is "PP" I plan to shoot Fireworks. www.eaglesnestphotography.com
asysin2leads I'm kissing arse 6,329 posts Likes: 3 Joined Dec 2006 Location: Lebanon, OH More info | PP stands for Post Processing (ie Photoshop) Kevin
Jeff Goldmember 1,462 posts Likes: 28 Joined Nov 2007 Location: 42° 34' N 87° 55' W Kenosha, WI More info | Nov 24, 2007 12:05 | #5 eaglesnest wrote in post #4375748 I plan to shoot Fireworks. Just a couple of samples. I was tickled to see that they came out as well as they did. They were taken hand held from our 20' boat in Lake Michigan. 24mm 1/80sec f2.8 ISO 1600 It was fun! Best of luck. Jeff
| Latest registered member is ANebinger 1064 guests, 186 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
