Thread started 26 Nov 2007 (Monday) 13:47
20D: Where Do You Read The Shutter Count?
Mike-DT6
Nov 26, 2007 13:47 |  #1
I often see people quoting the shutter count from their camera as if from the digital read-out, rather than a straight number, which suggests they are reading it from the camera itself somewhere. I have tried to find the counter on my 20D, but I can't. How can I find it on my camera?
For example, I see people quoting, when asked via an eBay question, a number such as '212-1234', which I understand (I think) means 11,234 actuations. Where are they reading this from?
Mike
Gear list
runninmann
what the heck do I know?
Gallery: 47 photos
Joined Feb 2006
Nov 26, 2007 13:50 |  #2
We 20D owners cannot reliably read a shutter count. If we are the original owner of the camera and have been conscientious with our CF card management, we can determine the count or estimate the count. To my understanding, only Canon (and, maybe, authorized independent repair centers) can determine the shutter count from the camera. 1D series owners can determine the count with available software applications.
Mike-DT6
Nov 26, 2007 13:54 |  #3
Okay, thanks :-) I have seen it on numerous occasions where 20D owners are quoting that numbering format from somewhere though! I've even looked at the EXIF information in my EOS Viewer Utility and it still doesn't quote the image numbers in that XXX-XXXX format, just the four-digit image number.
Mike
Gear list
runninmann
Gallery: 47 photos
Joined Feb 2006
Nov 26, 2007 14:00 |  #4
Mike-DT6 wrote in post #4388339 (external link)
Mike
Take a look at page 61 of the manual. i believe that will help you understand where the numbers come from.
Mike-DT6
Nov 26, 2007 14:56 |  #5
Thanks. I have actually read that, but it doesn't tell you where you can read the file numbering in that format.
I'm aware of the folder numbering system and that it's possible to put the folder number together with the last image number and come up with the XXX-XXXX number that way, but it appears from the way people are quoting the numbers that they are reading them from somewhere in that format. The reason why I say that is that some of the people appear not to know what the numbers mean, so I wouldn't have expected them to think of compiling the figures in that format unless they were reading them displayed like that.
Mike
Gear list
bauerman
discount on value meals
Joined Apr 2003
Nov 26, 2007 15:09 |  #6
It's all smoke and mirrors on a 20D - as an owner of the camera and using multiple CF cards - you can never know the count - no matter what pages you read in the manual.
Everything on a 10D/20D/30D/40D is a best estimate.
Mike-DT6
Nov 26, 2007 15:43 |  #7
Yes, it was beginning to look like a bit of a mystery! :-D
It's not a great issue; I was just curious, although it would be handy to know, when looking at used 20Ds to buy.
Mike
Gear list
LA ­ Smith
Apr 02, 2008 22:55 |  #8
:confused:
Mike
Take a photo with your 20D, then bring the photo up and hit the info button. The file number is in the upper right corner. My latest reading is 126-2673. I'm not sure what it's telling me though.
5D,20D, some lenses and stuff
pointerDixie214
Apr 02, 2008 23:00 |  #9
This is why I try my best to use the same CF card all the time... gives me the correct number as long as I do that... won't always be possible, but I try to bring my laptop on long trips to dump the files instead of popping in my spare CF card...
Canon EOS 30D * Tamron 17-50mm f/2.8 * Canon 70-200mm f/4L
wonderferret
Apr 03, 2008 03:25 |  #10
You could try this
http://zecoj.com …on-eos-20d-shutter-count/ (external link)
I've found it accurate with my 20d.
5D, 20D w BG-E2, 17-85IS, 70-200F4L, 50 F1.8 MkII, Tamron 28-75 F2.8 Xr Di, 430ex, 18-55 Kit Lens and some bags and cards and stuff.
Mike-DT6
Apr 03, 2008 07:28 |  #11
LA Smith wrote in post #5249305 (external link)
:confused:
Hello
Wow, it's ages since I last posted in this thread! :-D Since then I have found out what it all means, so I think I can help you here! :lol:
126-2673
This tells you that your camera has 2673 shutter actuations, assuming that the counter hasn't been messed up by putting in an un-formatted CF card with the file numbering from a different camera.
The numbers you see are as follows: The first digit is the number of times the camera has displayed blocks of 9999 actuations (as counted in the final four digits); the second and third digits mimic the first two digits in the final group of four (the thousands and the hundreds); the final four digits are the number of shutter actuations within the current block of 9999. For example:
101-0150 = 150 actuations.
167-6750 = 6750 actuations.
199-9999 = 9999 actuations.
200-0000 = 10,000 actuations.
201-0150 = 10,150 actuations.
267-6750 = 16,750 actuations.
299-9999 = 19,999 actuations.
300-0000 = 20,000 actuations.
367-6750 = 26,750 actuations.
And so on . . . . :-)
That's how I understand it. Someone please correct me if I have got that wrong.
Mike
Gear list
apersson850
Obviously it's a good thing
Gallery: 35 photos
Apr 03, 2008 08:09 as a reply to  @ Mike-DT6's post |  #12
They start with 100 (the Canon100 folder), then go to 101 after 10000 exposures.
So if 100-0150 is 150 exposures, then 101-0150 is 10150 exposures, and 367-6750 would be 2676750 exposures.
By then it would probably be all smoke of the mirrors, to (almost) quote another post above...
However, I think this has changed over time, so the reference above is perhaps true for a 20D? My 400D and 40D behave like I describe.
I tried the RAW file reading trick, for the 20D, on a file from the 40D. But it's not the same. These bytes were all zeros there, and I have indeed used the camera.
Anders
ryant35
Gallery: 16 photos
Apr 03, 2008 08:45 |  #13
apersson850 wrote in post #5251262 (external link)
The 20D resets it's counter at 9,999. It also resets the folders, which are 100 photographer per folder.
5DMK4, 7DMK2, 24-104mm f/4 L, 70-200mm f/2.8 IS II, 100-400mm f/4.5-5.6 IS MK2, 17-40mm f/4, 100mm f/2.8 Macro, 35mm f/1.4,1.4X & 2X TC III 580EXII
www.ryantorresphotogra​phy.com (external link)Photography Facebook Fan Page (external link)
Mike-DT6
Apr 03, 2008 08:57 |  #14
Anders, yes, I was referring to the 20D, as was LA Smith with his post. :-)
Mike
Gear list
ryant35
Gallery: 16 photos
Apr 03, 2008 09:06 |  #15
Ok I tried this website and downloaded the program, below is the final output from the software.
1B as shortint: 27
1B 35 as word: 6965
1B 35 as integer: 6965
1B 35 00 00 as longint: 456458240
1B 35 00 00 as 32 bit IEEE single: 1.49719690872098E-22
1B 35 00 00 00 00 00 00 as 64 bit IEEE double: 1.29557291947931E-177
It looks like it is showing my total actuations to be 6,965.
I know I have almost 100k actuations so I guess this isn't accurate. Also the raw image I used image number was 1077.CR2
5,688 views & 0 likes for this thread, 14 members have posted to it and it is followed by 3 members.
1689 guests, 115 members online
