Ok perhaps im slightly retarded, or doing something wrong or not noticing something..but Im having an issue with the AF on my mk2n.... I dont normally use the AF and when I do I usually use the center AF point(by holding the af button and scrolling the wheel). I have recently started shooting bicicle riding and its much faster than the things im used to so its tough to keep the center AF point on the person 100% of the time. Everytime the person gets away from that 1 middle square the camera focuses somewhere else....
When scrolling through the AF Point selection, it will only chose 1 point somewhere, or the points around the outsdide of the set of AF points. My question is this: With the setting where all of the outer points light up, are the ones inside that "circle" active as well or just the outer ones? Im looking for better, more consistant AF. I know a part of the problem could be the lens I was using at the time(28-75) and didnt try the 70-200 but I figured Id ask you guys!
Thanks alot
