... but will all lenses with 52mm filter size fit into the LA-DC52 linsadepter?
And will all work with the camera?
I'm pretty new to this so can someone please explain it to me?
Thanx
/Grizzly
GrizzlyBear Hatchling 1 post Joined Jul 2003 More info | Aug 31, 2004 10:19 | #1 ... but will all lenses with 52mm filter size fit into the LA-DC52 linsadepter?
DonSchaeffer Member 174 posts Joined Nov 2003 Location: Winnipeg, Manitoba More info | Aug 31, 2004 15:09 | #2 The lens adapter has a 52 mm screw in mount. Your auxillary lens with a 52 mm male screw in will fit perfectly. I use a aux lens with a 49 mm mount so I had to buy a 52->49 mm adapter.
JohnnyE Senior Member 470 posts Joined Jan 2003 More info | Aug 31, 2004 15:09 | #3 Fit? Yes. Work? Not all will.
DonSchaeffer Member 174 posts Joined Nov 2003 Location: Winnipeg, Manitoba More info | Sep 01, 2004 02:06 | #4 Sorry, you are right Johnny. I wasn't looking carefully. The only lenses that will work are supplementary lenses. These supplementary lenses work like telescopes. If you look into through you will see an image. They are not real camera lenses. They just magnify or de-magnify the image the camera sees.
| Latest registered member is Thunderstream 1780 guests, 113 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
