Thread started 30 Nov 2007 (Friday) 12:53
sharpness problem
psxindo
Nov 30, 2007 12:53 |  #1
Hi,
I use lightroom.
when I look at my picture in lightroom it looks sharper than after I convert it to Jpeg.
Usually my setting in lightroom are 50~80 amount, 1.0, 25~40, 50~70.
then I would resize the picture to 1800-1200 pixels.
does the resizing making my pictures less sharp?
I'm still learning to do PP.
5D mkIII | 5D mkII | 6D | EOS M | 16-35L | 24-70L | 70-200L 2.8 IS mkII | EF-M 22 | 50 1.4 | 85L | 100 2.8 macro | Tamron 17-50 2.8 | 2x 580 ex II | 580 ex | 2x sunpak 383 | 134GB CF |
Wishlist | 14L | 24L | 35L | 50L | 100L macro | 135L | 15 2.8 FE | 17L 4 TS | 45 2.8 TS | 90 2.8 TS |
kevin_c
Nov 30, 2007 13:30 |  #2
When you re-size you will need to sharpen slightly.
Personally I use the default settings in LR, I believe this gives a small amount of 'capture sharpening' to the RAW image. Any more sharpening is done in Photoshop and depends upon the size of the image and the output (screen/web or print).
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
536 views & 0 likes for this thread
sharpness problem
Latest registered member is mcsdet
1546 guests, 273 members online
