http://aminphoto.blogspot.com …at-digital-ever-have.html![]()
It took me quite a while to get the author's drift ...
roli_bark Senior Member 918 posts Joined Oct 2005 More info | Dec 03, 2007 03:44 | #1 http://aminphoto.blogspot.com …at-digital-ever-have.html
JeffreyG "my bits and pieces are all hard" More info | Dec 03, 2007 05:25 | #2 He makes good points. I had recognized the macro implications for some time. My mother takes hand held flower pictures in her garden all the time with a P&S while I'm lugging a tripod and shooting at f/11. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Nick_C Goldmember 4,042 posts Joined Jul 2006 Location: Tin Mine Country (Cornwall UK) More info | Dec 03, 2007 05:43 | #3 I just downloaded his raw test images, the 5D shot is severly underexposed by just over 4 stops & bringing up the exposure when at iso3200 makes it pretty hard to see what is going on, what was he thinking?
asabet Senior Member 301 posts Joined Dec 2006 Location: Baltimore, MD (US) More info | Dec 03, 2007 06:07 | #4 Nick_C wrote in post #4430481 I just downloaded his raw test images, the 5D shot is severly underexposed by just over 4 stops & bringing up the exposure when at iso3200 makes it pretty hard to see what is going on, what was he thinking? ![]() (update): looking through all the noise I can see there is much more dof on the 5D shot over the other one, hmm strange, maybe ive missed the point also ![]() Hi, I posted that blog post and would be happy to address your points. Based on the format sizes of the two cameras, one can calculate the f-number needed to get the same DOF for each given a fixed subject distance, output size, diagonal angle of view (the diagonal is used here rather than height or width since the aspect ratios differ). When f/18 is used on the 5D, f/3.9 will give the same DOF using the Ricoh (assuming fixed subject distance, output size, and diagonal AOV). The DOF appears greater with the 5D mainly because the aspect ratio is 3:2 vs 4:3, thus including less vertical angle of view, and secondarily because the vantage point for the 5D is slightly higher since each camera was sitting on the ground using a self timer for the shot (the 5D is taller). You can check for yourself using an independent source such as DOF Master that the settings I used give the same DOF for the two systems. The underexposure of the 5D is a consequence of the fact that it has to be stopped down just over 4 1/3 stops to get the same DOF, and that this test required each camera to use the same shutter speed. Thus, the ISO had to be maxed (at ISO3200, which is two stops more than the Ricoh) and then pushed just over 2 1/3 stops additionally to match the apparent exposure of the Ricoh. Not sure what app you are using to push it an additional 4 stops, but that results in overexposure in my case. In fact, I found it interesting and consistent that Lightroom, on its own, chose +2.4 stops when I simply selected auto exposure. www.aminsabet.com
JMHPhotography Goldmember 4,784 posts Likes: 1 Joined May 2005 Location: New Hampshire More info | Dec 03, 2007 06:31 | #5 Why did this test require the same shutter speed? And why was the ISO speed allowed to change? I don't get the point of this execise. I'm no genius, but given everything I know about photography (admittedly it's not everything...) tells me that in order to get the same comparison picture in terms of DOF and exposure, I would have to leave the ISO capped at 800 and adjust the shutter speed to get a GOOD exposure. I'd certainly need a tripod for the 5D which is to be expected... but it would be the same image in terms of exposure and DOF, but I gaurantee that image quality results would be much different. ~John
asabet Senior Member 301 posts Joined Dec 2006 Location: Baltimore, MD (US) More info | Dec 03, 2007 06:45 | #6 There's no right way to do such a test. You might find more than a certain level of noise acceptable for each camera and cap the ISO accordingly. I was doing a test with low light street photography in mind. In those circumstances, I often encounter moving subjects (hence shutter speed matters if one wants the picture a certain way) and deep DOF. Clearly capping the ISO and varying the shutter speed favors the 5D, but we don't need a test to prove that! In the great majority of situations, the 5D will have better image quality than a small sensor camera. What I found interesting was that there is one type of situation - one which I happen to encounter periodically - in which a small sensor camera may prevail. www.aminsabet.com
Dec 03, 2007 06:52 | #7 Nick_C wrote in post #4430481 I just downloaded his raw test images, the 5D shot is severly underexposed by just over 4 stops & bringing up the exposure when at iso3200 makes it pretty hard to see what is going on, what was he thinking? How did you figure that out [4 stops underexposure] from the RAW ?
asabet Senior Member 301 posts Joined Dec 2006 Location: Baltimore, MD (US) More info | Dec 03, 2007 06:55 | #8 roli_bark wrote in post #4430624 How did you figure that out [4 stops underexposure] from the RAW ? Here's what the 5D RAW looks like pushed in Lightroom.
I think I know what's going on here. I'm seeing less pushing because of the brightness setting in LR (added automatically to both Ricoh and Canon files during autoexposure). Either way, what at stake here is not whether Canon and Ricoh are using ISO values the same way. When you set both cameras to the same shutter speed, framing, DOF, and output size, then whatever ISO is needed to get the same apparent exposure is what one needs for this particular test. If that is +4 in your method, then so be it. In my processing algorithm, the histograms lined up at +2.4. www.aminsabet.com
Dec 03, 2007 06:58 | #9 asabet wrote in post #4430614 What I found interesting was that there is one type of situation - one which I happen to encounter periodically - in which a small sensor camera may prevail. A "fairer" comparison to Richo's smaller sensor would be using a wider lens [thus getting higher DOF] for the 5D, setting SAME shutter/ISO, and cropping the image accordingly.
Dec 03, 2007 07:12 | #10 JeffreyG wrote in post #4430457 He makes good points. I had recognized the macro implications for some time. My mother takes hand held flower pictures in her garden all the time with a P&S while I'm lugging a tripod and shooting at f/11. Razor thin DOF is not always desireable. The APS-C dSLRs are in some respects a nice compromise. They can get shallow DOF with primes when it is wanted (unlike most P&S) but they don't have to be stopped down as much going the other way. My 10-22 is focussed at infinity for the most part even when it is wide open. That's true. Different strokes for different folks.
asabet Senior Member 301 posts Joined Dec 2006 Location: Baltimore, MD (US) More info | Dec 03, 2007 07:48 | #11 roli_bark wrote in post #4430644 A "fairer" comparison to Richo's smaller sensor would be using a wider lens [thus getting higher DOF] for the 5D, setting SAME shutter/ISO, and cropping the image accordingly. That would be an interesting test, and I'm confident it would favor the 5D; however I don't see how it would be any fairer (unless you define "fairer" by which test favors the 5D www.aminsabet.com
Nick_C Goldmember 4,042 posts Joined Jul 2006 Location: Tin Mine Country (Cornwall UK) More info | Dec 03, 2007 09:09 | #12 I used CS3, when I said 4 stops it was only a rough guide, even with 4 stops there are only a few areas that are blown, the carpet in front is ok..
Nick_C Goldmember 4,042 posts Joined Jul 2006 Location: Tin Mine Country (Cornwall UK) More info | Dec 03, 2007 09:14 | #13 [QUOTE=asabet;4430796]That would be an interesting test, and I'm confident it would favor the 5D; however I don't see how it would be any fairer (unless you define "fairer" by which test favors the 5D
Nick_C Goldmember 4,042 posts Joined Jul 2006 Location: Tin Mine Country (Cornwall UK) More info | Dec 03, 2007 09:16 | #14 asabet wrote in post #4430632 Here's what the 5D RAW looks like pushed in Lightroom.
I think I know what's going on here. I'm seeing less pushing because of the brightness setting in LR (added automatically to both Ricoh and Canon files during autoexposure). Either way, what at stake here is not whether Canon and Ricoh are using ISO values the same way. When you set both cameras to the same shutter speed, framing, DOF, and output size, then whatever ISO is needed to get the same apparent exposure is what one needs for this particular test. If that is +4 in your method, then so be it. In my processing algorithm, the histograms lined up at +2.4. Yes its too much brightness on that one, although I get your point, this isnt what you were demonstrating!
Dec 03, 2007 09:26 | #15 asabet wrote in post #4430796 That would be an interesting test, and I'm confident it would favor the 5D; however I don't see how it would be any fairer (unless you define "fairer" by which test favors the 5D By "fairer" I mean same shooting conditions. Same shooting conditions are, among other things, same perspective. Same perspective can be achieved only by using a wider-angel lens for the larger sensor camera.
| Latest registered member is semonsters 1338 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
