Under "Quality" setting I don't see a raw option.
Alex
AlexMar Mostly Lurking 14 posts Joined Oct 2007 More info | Dec 03, 2007 20:58 | #1 Under "Quality" setting I don't see a raw option. Canon 40D 580EX ll Flash
basroil Cream of the Crop 8,015 posts Likes: 2 Joined Mar 2006 Location: STL/Clayton, MO| NJ More info | Dec 03, 2007 21:00 | #2 that's because the box modes don't support anything, they are full auto... I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing.
ChucklesKY Senior Member 353 posts Joined Nov 2007 Location: Bluegrass, KY More info | You can't shoot RAW in the "Basic" modes such as portrait, landscape, sports, and such. You should go manual or aperature priority. I shoot only manual, RAW, neutral. Canon EOS 40D || 10-22mm EF-S || 24-70mm f/2.8L ||70-200mm f/2.8L IS || 50mm f/1.8 II || 60mm f/2.8 Macro EF-S
Dec 03, 2007 21:15 | #4 switch it to Av, set value to the lowest number possible, and shoot... anything on the other side of Tv is practically useless Canon 40D 580EX ll Flash
overclock Goldmember 1,191 posts Joined Jan 2005 Location: Fort Worth, TX More info | Dec 03, 2007 21:28 | #5 Alex Mar wrote in post #4435334 switch it to Av, set value to the lowest number possible, and shoot... anything on the other side of Tv is practically useless _______________ I tried that and the shutter closes and never opens again? You must have a small aperture lens or very low light or both. What is it you are testing on? Conditions?
I have plenty of light and I tried the highest and lowest apertures and the shutter never opens back up. Canon 40D 580EX ll Flash
red_click Member 32 posts Joined Sep 2005 More info | Dec 03, 2007 22:45 | #7 Alex Mar wrote in post #4435840 I have plenty of light and I tried the highest and lowest apertures and the shutter never opens back up.
Zonieart Senior Member 602 posts Likes: 2 Joined Dec 2006 Location: Tucson Arizona More info | Dec 03, 2007 23:16 | #8 Alex Mar wrote in post #4435840 I have plenty of light and I tried the highest and lowest apertures and the shutter never opens back up. Alex - What lens are you using? Make sure the batteries are fully charged. Place the camera in Av mode. Set the aperature to f5.6 and see if you can get a shot. Did you remember to put a CF card in? Retired and Loving it!
PerryGe Batteries? We don't need no... . . . or cards. More info | Dec 03, 2007 23:40 | #9 Do you have mirror lock-up on perchance? It's in your custom functions, could've turned it on by accident? Perry | www.perryge.com
"Alex - What lens are you using? Make sure the batteries are fully charged. Place the camera in Av mode. Set the aperature to f5.6 and see if you can get a shot." Canon 40D 580EX ll Flash
ChucklesKY Senior Member 353 posts Joined Nov 2007 Location: Bluegrass, KY More info | Dec 04, 2007 08:59 | #11 Alex Mar wrote in post #4435840 I have plenty of light and I tried the highest and lowest apertures and the shutter never opens back up. What the. . . .? Canon EOS 40D || 10-22mm EF-S || 24-70mm f/2.8L ||70-200mm f/2.8L IS || 50mm f/1.8 II || 60mm f/2.8 Macro EF-S
P51Mstg Goldmember 1,336 posts Likes: 2 Joined Feb 2007 Location: Mt. Carmel, TN More info | Alex: Too Much Camera Stuff......
"You have the camera set on the GREEN BOX, switch it to P; Tv; A; etc and then you can shoot RAW. On GREEN BOX (Full automatic) RAW is not an option." Canon 40D 580EX ll Flash
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 04, 2007 10:15 | #14 Look in your menu and see if somebody enabled mirror lockup. If Mirror lockup is on you press the shutter once to raise the mirror and a second time to actually take the picture. If you don't press the shutter that second time, the mirror will return after about 20 sec. Jon
It must be on because after pressing the shutter a second time it did take the picture and I can see it on the display. The problem is that when I look at my menu under "mirror lockup" and click it a message comes on "cannot register more items, delete an item and then register" so I can't see if it's on or not and if it is on I can't change it to off. If I delete an item can I get it back or is it then gone from the camera? Canon 40D 580EX ll Flash
| Latest registered member was a spammer, and banned as such! 2689 guests, 146 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
