TMR Design wrote in post #4445841
Using Auto White Balance will give you the least consistent results.
That part is true, but I don't concur with the rest of your post, at least in the context of a RAW workflow.
You adjust the WB on one shot, select the rest of the shots in the group and sync them. It only takes a few clicks and it makes no difference how consistent they were to start. That's part of the beauty of RAW.
I use AWB most of the time, just to give me something realistic on the camera LCD. It has no bearing on the workflow, nor the final output.
I have noticed that when I use the white balance flash indoors the picture is tinted orange.
To the OP: This is most likely caused by the tunsgten ambient lighting. Basically your options are: 1) Use a fast shutter speed (1/200) to minimize the ambient light, or 2) Use a CTO gel on your flash to match the color temp of the ambient, and adjust your white balance for the tungsten.
