Thread started 07 Dec 2007 (Friday) 00:22
Canon Speedlite ML-1?
macroimage
Dec 07, 2007 00:22 |  #1
Hi, I have an opportunity to purchase a slightly used Canon ML-1 ringlight for a good price. I'd like to use it with my Canon Rebel XTi (400D). Usually only EX flashes work right though. Could the ML-1 be made to fire even if it is at full power? I could use the aperture to control the exposure. I was thinking of mounting it on the EF-S 60mm f/2.8 Macro USM. Thanks for any advice on this.
Photo Gear
nadtz
Dec 07, 2007 00:53 |  #2
Looks like you can get a decent idea of what you are getting into via
http://www.mir.com.my …ared/Macrolites​/index.htm (external link)
There is a link to the manual on that page. In a nutshell it looks like the flash should be usable so long as you don't mind manually dialing in the settings, I just checked the manual really quickly though, hopefully any gotchas someone else will know of.
macroimage
Dec 07, 2007 21:58 as a reply to  @ nadtz's post |  #3
Hi, Thanks for your reply. I think I'll just have to try it. I've read that some (most?) non EX speedlites will not fire at all on digital, not manual, not anything.
Photo Gear
braduardo
Dec 07, 2007 22:12 |  #4
It should fire without any issues. I would advise checking the trigger voltage to make sure that it doesn't overpower your camera and fry it out.
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 07, 2007 22:25 |  #5
I found a copy of the instruction manual for the ML-1 on the net:
http://www.canonfd.com​/ml1ind.htm (external link)
Bob
2,103 views & 0 likes for this thread, 4 members have posted to it.
489 guests, 122 members online
