Thread started 09 Dec 2007 (Sunday) 18:22
Reversed lens help - Err message
H20boy
Dec 09, 2007 18:22 |  #1
I need a little advice here.
I have tried these combinations on both my 5d and the 40d, and both times, I get a ERR message after trying to take a shot.
My combinations are these...
(1) Life Size Converter + body/58mm reversing ring + reversed 28mm super-tak
(2) Sigma 1.4x + Extension tubes + body/58mm reversing ring + reversed super-tak
I am assuming that the camera won't create an exposure if it doesn't recognize a lens contact. The LSC and TC both have connection pins, and when I go reverseing using the body/ring, it thinks there isn't a lens?
Help! ???
Matt l My Galleries (external link)
5d2 l 1d3 l 24-70/2.8 l Σ 50/1.4 l 70-200/2.8 IS l Σ 120-300/2.8 l 135/2 l 15/2.8 FE l Tam 90mac
H20boy
Dec 09, 2007 18:25 |  #2
If I remove the LSC or Teleconverter, the camera allows an exposure with just the body/reversing ring + reversed lens. I'm miffed...
LordV
Dec 10, 2007 01:31 |  #3
Not sure why you get that error but you don't normally useTC's with a body reversed lens. Suspect you can't use an electronic coupled TC without having an electronically coupled lens. So I'd guess if you want to do this you would have to tape the TCs electronic contacts. I certainly had no problem with this sort of thing using couplings with no contacts.
Brian V.
Macro Hints and tips
H20boy
Dec 10, 2007 09:25 |  #4
thanks for the tip Brian. will try this out...just trying to get some higher magnification without sacrificing too much working distance... I know, we're talking inches here, but I am thinking of the lighting too, and getting it in front of the subject with an off camera flash or strobe. If the lens is practically touching my subject, it is hard to evenly light. I do not have a macro flash either.
let's see how this works out, and again, thanks!
H20boy
Dec 10, 2007 20:35 |  #5
Taping the contacts on the TC and LSC did the trick. Thanks again. I'm off and shooting again, at what I calculate, is almost 4:1 magnification.
LordV
Dec 11, 2007 00:59 |  #6
H20boy wrote in post #4479634 (external link)
Excellent - I think some of the TC's are just too clever and do communicate with the camera.
Brian V.
1,724 views & 0 likes for this thread, 2 members have posted to it.
1061 guests, 104 members online
