Thread started 11 Dec 2007 (Tuesday) 22:29
RAW processing?
DAMphyne
"the more I post, the less accurate..."
Joined Feb 2003
Dec 11, 2007 22:29 |  #1
Is there an automatic processing program that will consistently produce JPEG's the quality I get right from my camera?
Or do I have to monitor the processes to get good results?
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute.";)
www.damphyne.com (external link)
tim
Light Bringer
Dec 12, 2007 01:49 |  #2
Batch processing in Adobe Camera Raw (ie photoshop) with auto turned off and you'll do pretty well. You might like to increase sharpness and contrast a bit.
davidcrebelxt
Dec 12, 2007 07:29 |  #3
DAMphyne wrote in post #4487221 (external link)
I use a Rebel XT...
Using Canon's Zoombrowser at default settings gives me jpegs that I rarely (if ever) have been able to distinguish from the in-camera jpeg shot along side of the RAW image... but the good thing about RAW is that when the camera DOESN'T quite process it right, you're not stuck with it and you've got control. So once you're skilled at RAW, you should be able to consistently come up with better images than in-camera. But I too still like the ability to just see WHAT the camera would have come up with occasionaly.
(I had emailed Canon awhile back what settings in DPP would mimic the in-camera-jpeg. The said there were none. They suggested Zoombrowser, since its algorithms were closer (or the same) as how the DigicII chip processed the images internally.) I do still prefer DPP over zoombrowser when I'm going to do adjustments, however.
Consistency, as you mention, is a problem STILL with ACR and Lightroom. I can set a preset that will look Great on one image... but not for anything else. Or I can set a preset that looks "decent" on most images and use that as a starting point for further adjustments when desired.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
DAMphyne
Joined Feb 2003
Dec 12, 2007 08:19 |  #4
This is my problem with shooting RAW.
I get consistently good or very good quality from the out of camera JPEGs. I can't see myself getting the same overall quality with my limited ability as a computer operator.
I understand that there may be some advantage using RAW when it comes to color balance, but the time it would take me to acquire skills to match, or come close to, the OOC images would be very time consuming.
Time, I think, better spent shooting pictures.
If I could download files into a process that would, in the end, give me comparable quality that I get from my camera JEPGs, I'd probably give RAW an effort.
David
Digital set me free
Dermit
Joined Nov 2005
Dec 12, 2007 08:52 |  #5
I used to race bikes, that's bicycles, not motorcycles, and I was always amazed that a competitor would spend $500 to buy a component to take a couple ounces off his bike but was 20 pounds overweight himself.
The point is that often times being the best, getting the best results, is almost always a product of more work. Usually the more you put into something the better it is. Thus is the formula for photography and post processing. I just do not understand buying a really nice camera, spending a fortune on "L" glass and then resort to 'accepting' a file as processed by the camera when you could put in a little extra work and tune it to be a lot closer to the best potential for that image if you had only shot in RAW and learned how to process it.
Pro photography is very competitive and if you do not go that extra mile that makes your images stand out then chances are your competition will and you will soon be out gunned.
Yes, the extra attention you spend in fine tuning a RAW file can be time consuming. I shoot around 25,000 images a year. All in RAW and mostly professionally for clients who pay for my work. I do all my own post processing using Lightroom and PS CS3. The last 3 weeks alone I've taken 5,000 images and I have a wedding to do this Friday and another on Tuesday next week. Oh, and did I mention that I have a 'regular' job (40 hr/week) totally unrealted to photograhpy that takes a lot of my time?
The point is that I shoot a lot and post process everything myself. This high quantity demand requires me to have a workflow and a system that absolutely delivers good quality images in a timely manner. You can not compete very well without being very good at post processing or pay someone else to do it. Not learning how to get the best image from a RAW file shot with great gear means you spent a lot of money to get images that are not representing what the gear is capable of. What a waste of money.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
PhotosGuy
Moderator
Joined Feb 2004
Dec 12, 2007 09:00 |  #6
I understand that there may be some advantage using RAW...
Here's one: A max jpg from my 20D is about 2,754 KB. The exact same shot with the jpg extracted from the 12-bit RAW "negative" is 4,315 KB which is 1.57X larger.
Whatever info is in my jpg is a lot more detailed than what comes right out of the camera. Why throw those extra bits away?
Here's another: You might think you won't see the difference in a web image on your screen, but that's not true. Look at post 58 on page 2 in this thread:
Auto White Balance - works really well
https://photography-on-the.net …hp?p=2208481&po​stcount=58
For me, RAW is faster. If I'm not batch processing, I'd have to:
Open the image.
Open the correction dialog box. Make that correction. Close it.
Open the next correction dialog box. Make that correction. Close it.
Etc, etc...
With RAW, I can just move this slider, move that slider, etc 'till it's time to convert the images. Much faster for me. And, while I have made Actions to "Open the next correction dialog box." in PS, I still prefer to make all possible changes before conversion, which I feel is the same as working in 16-bit in PS.
-=The RAW Faqs=- RAW Processing info and links
In2Photos
Dec 12, 2007 09:13 |  #7
DAMphyne wrote in post #4489059 (external link)
IMO if all you plan to do with RAW files is turn them into JPEGs without making any adjustments, then there is no need to shoot RAW. Don't fix what isn't broke. If you are happy with the results from your camera in JPEG then stick with it. I never liked the JPEG images that my camera produced so I switched to RAW. You mileage may vary.
Current Gear and Feedback| My Pbase Galleryexternal link | mdsportsphoto.comexternal linkhttps://photography-on-the.net/forum/showthre​ad.php?t=835433
DAMphyne
Joined Feb 2003
Dec 12, 2007 15:04 |  #8
Well, first of all I'm not a "Pro", so I don't have the 'push to produce' nagging me when I take pictures.
I guess I don't get that impressed with perfect pixel properties, so file size isn't as important as impact and perception when looking at photos in general.
I have yet to walk into a room with photos on the wall and tried to see if they had faulty pixels. I think it's best to view the image as the artist/photographer presents it. If they wanted us to pixel peep it would be wall size instead of, say, an 8x10.
I'm still hanging on to the feeling that I'd rather spend more time shooting than processing.
I figured if I could find a quick and easy program that would give me comparably better pics than the built in processor, I'd try out the RAW.
David
Digital set me free
Tixeon
Joined Oct 2004
Dec 12, 2007 17:52 |  #9
DAMphyne wrote in post #4491962 (external link)
I doubt seriously that you will find a program that is quick & easy and will give you (initially) results that you are used to with your jpg's. As with any computer program, you will need to spend some time to learn the best & most efficient settings that give you the results you expect. Many here on POTN swear by Digital Photo Pro & a few swear at it. DPP does seem to be one of the most useful & easiest to use for RAW files.
It's good that you are not under professional pressure, therefore, you can take all the time you need. Good luck.....
Tim
______
Any cat owner will tell you -- no one really owns a cat...
In2Photos
Dec 12, 2007 19:33 |  #10
Again, based in your response I don't believe RAW is the best choice for you. Stick with JPEGs, there is nothing wrong with that choice. :)
Dermit
Joined Nov 2005
Dec 13, 2007 08:06 |  #11
...and next time you want to buy a V12 Jaguar and only run it on 6 cyclinders give me a call, I might be able to save you some money.
PhotosGuy
Moderator
Joined Feb 2004
Dec 13, 2007 08:38 |  #12
I hear that Yugos last forever? ;)
1,724 views & 0 likes for this thread
RAW processing?
Latest registered member is rondimar
1113 guests, 354 members online
