Thread started 11 Dec 2007 (Tuesday) 22:38
Is there a lens filter to help with
Donte
Dec 11, 2007 22:38 |  #1
Sorry if this is a noob question but that’s what I am. I always get these spots in my pics when there is a bright light source i.e. candle, sun and light bulbs. Is there any type of filter that I can put on my lens stop these? Or could my cheap filter (sunpak ultraviolet) be the cause? I have the 40D with the kit lens.
nicksan
Man I Like to Fart
Dec 11, 2007 22:45 |  #2
Graduated Neutral Density Filter(GND).
Well maybe not for that particular pic...but look into it just the same.
Mark_Cohran
Joined Jul 2002
Dec 11, 2007 23:42 |  #3
Is there any type of filter that I can put on my lens stop these? No. When shooting directly into the sun or other light sources, the more glass you put in front of your lens, the more likely you are to get adverse refraction.
Yes. Take the filter off and try the shot without it. You should see some improvement, but it may not go away entirely.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
71sbeetle
Gallery: 31 photos
Dec 12, 2007 00:02 as a reply to  @ Mark_Cohran's post |  #4
that cheap UV is also degrading your Image Quality, take it off and throw it away !
gareymartin.com (external link)
gear list | CPS.
Feedback:
eBay (external link) | POTN
VWVortex (external link)
Donte
Dec 12, 2007 00:49 |  #5
Which one should I get? I want something that will protect my lens.
Super-Nicko
Dec 12, 2007 02:26 |  #6
Try hoya Pro1 UV filters... i use them on my lenses to protect the front element..
http://www.bhphotovide​o.com …ge.jsp&A=search​&Q=*&bhs=t (external link)
This text is taken from the D-D-Photographics site...
"...Standard UV & Circular Polariser - Coated on both sides. Transmits about 95% of light. Offers good quality protection for lenses.
HMC - Multi-coated with three layers on each side. Minimises reflection at the filter surfaces which reduces flare and ghosting. Provides average light transmission of over 97%, giving sharp contrast and well balanced color.
Super Pro 1 (UV) - 12 layers of super multi-coating applied to the surfaces, producing an average transmission of 99.7%.
Super Pro 1 (Circular Polariser) - 7 layers of Super Multi Coating on the rear surface to eliminate internal reflection and ghosting. Slim profile of just 5mm avoids any vignetting problems and makes them ideal for use with wide angle lenses...."
http://www.d-d-photographics.com/filt​ers.htm (external link) Aussie site
My gallery - just posted some of my top shots (external link)
1DmkIII / 5DMKII [50mm f1.4] [85mm f1.8] [100mm f2.8 MACRO] [17-40mm f/4L] [24-70mm f/2.8L USM] [24-105mm f/4L IS USM] [COLOR=black][COLOR=bl​ack][[COLOR=black]100-400mm f/4.5-f 5.6L IS USM] Canon 1.4xII - Speedlite 580EXII - EPSON P-5000 - Lowepro Bags - Manfrotto 682B Monopod & 055XproB Tripod - 488RC2
Super-Nicko
Dec 12, 2007 02:27 |  #7
Also try reading this "sticky" in the lens section...
https://photography-on-the.net/forum/showthre​ad.php?t=368177
Lowner
"I'm the original idiot"
Dec 12, 2007 05:27 |  #8
Donte,
What do you mean when you say spots? I cannot see spots on your image. Yes, theres a great big yellow "spot" just left of centre, I think some experts call it "The Sun".
You have done well not to get internal reflections in the lens. Maybe because its so close to straight on.
If you want to balance the exposure so that you've got more detail in the foreground and keep the sun in check, then as has already been said, invest in a set of NG filters. Don't throw away your UV filter, just remember to remove it when you are taking shots like this against the light.
Richard
Richard
71sbeetle
Gallery: 31 photos
Dec 12, 2007 10:06 |  #9
Lowner wrote in post #4488578 (external link)
Richard
cheap filter reduce image quality ..... by a lot ! do a search you'll see my comparison pics
gear list | CPS.
Feedback:
tzalman
Fatal attraction.
Dec 12, 2007 11:34 |  #10
A good hood and the lens cap will protect your lens just as well and the hood will improve many photos
Elie / אלי
1,116 views & 0 likes for this thread, 7 members have posted to it.
1182 guests, 178 members online
