Thread started 12 Dec 2007 (Wednesday) 02:58
Which Lowepro Lens Case for 17-55mm f/2.8?
jtown
Dec 12, 2007 02:58 |  #1
I need to pick up a lens case and was wondering which Lowepro version would fit perfectly for this lens. I also want to use it for my 10-22mm, but that one is smaller than the 17-55 so the same case should make do when I swap lenses (I only have 2).
Or are there any other lens cases that would work well with the 17-55?
Raven
Joined Jan 2005
Dec 12, 2007 12:27 |  #2
According to B&H Photo, you need the Lowepro 1W
http://www.bhphotovide​o.com …541W10_Lens_Cas​e_1W_.html (external link)
Jim ~ Canon EOS 7D & 40D | Canon Powershot G5x, G16, G12 & G10 | Sony Cyber-shot RX100 M2 | Canon 17-40mm f/4 L | Canon 24-105mm f/4 L IS | Canon 70-200mm f/4 L IS | Canon 100mm f/2.8 Macro |
Canon 60mm f/2.8 Macro | Tamron 28-75mm f/2.8 | Tokina 12-24mm f/4 | Kenko 1.4x Pro300 DG TC
Wilt
Dec 12, 2007 13:04 |  #3
Lens Case 1W is what Lowepro chart says is right. I have one, and the 17-55 with reversed hood goes in reasonably easily and comes out with a bit more effort (since the hood edges are going in the counter direction when removing it from the case) and the lens is a bit tall with mounted filter and lens cap, but it does fit.
jtown
Dec 14, 2007 03:10 |  #4
Sweet. I can't believe I can't read ... haha. Thanks for the help.
3,146 views & 0 likes for this thread, 3 members have posted to it.
1460 guests, 173 members online
