Is there any advantage to shooting only raw and letting Canon's DPP process the images into jpegs vs. producing jpegs in camera? I've heard the files are larger by using DPP but don't know if this translates into better jpegs.
JohnE Goldmember 1,025 posts Likes: 1 Joined May 2006 Location: Amarillo, TX More info | Dec 13, 2007 14:45 | #1 Is there any advantage to shooting only raw and letting Canon's DPP process the images into jpegs vs. producing jpegs in camera? I've heard the files are larger by using DPP but don't know if this translates into better jpegs. John Elser
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | Dec 13, 2007 14:50 | #2 At least if you shoot RAW you are the one in control of the end result, not the camera. -- K e v i n --
sapearl Cream of the Crop More info | Dec 13, 2007 14:53 | #3 I'm trying to remember where I read it, but you are better off having your PC/Mac and program of choice convert the RAW file to JPG as opposed to letting the camera do it. GEAR LIST
rooeey -Shorty- 2,554 posts Likes: 5 Joined May 2007 Location: Sydney Australia More info | Dec 13, 2007 15:00 | #4 There is a lot of argument over this subject of which a forum search would uncover for you. 1D MK111 , 5D Classic,24-70F2.8, 16-35F2.8, 70-200F2.8 IS a 430EXII 2x 580EXII and a Mac...
sapearl Cream of the Crop More info | Dec 13, 2007 15:04 | #5 Now that I try to remember, I think it may have been one of Scott Kelby's books that claimed you were better off using the CPU in your PC since it's under "less pressure" to perform. GEAR LIST
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Dec 13, 2007 15:12 | #6 If the question is specifically on shooting large fine JPEG vs. shooting RAW and converting in DPP without adjustment, then DPP at least gives you the option of less JPEG compression and higher quality (technically) than the camera will produce. You also have the option to convert to TIFF (8 or 16 bit) with no compression at all. "If you're not having fun, your pictures will reflect that." - Joe McNally
frankgindc Member 104 posts Joined Aug 2007 More info | Dec 13, 2007 15:27 | #7 Personally, I'm of two minds (at least) on this:
Dec 13, 2007 15:44 | #8 Thank you all for your imput. I was just wondering if JPEGS converted from raw were better since their files are larger. I've been shooting RAW + JPEG recently just to have the best of both worlds. However, when converting my RAW files into JPEGs using ACR, I never can seem to the right mix of all the slider adjustments, and the JPEGs from the camera always seem to look better (skin tones are especially hard to get right). I am getting the feeling that I should shoot raw and let Canon's DPP convert to TIFF or JPEG which would give me better results. John Elser
frankgindc Member 104 posts Joined Aug 2007 More info | Dec 13, 2007 17:00 | #9 Yeah, that's the thing: Canon knows how to interpret their RAW files better than the 3rd party vendors. You might be able to get close or in some cases better conversions with the other converters but it can take alot of trial and error. I use Lightroom (which has the same RAW converter as ACR) for its ease of use and workflow features, but I think that DPP usually does better images.
davidcrebelxt Goldmember 3,016 posts Joined Dec 2006 Location: Missouri, USA More info | Dec 13, 2007 17:44 | #10 Dpp will even need adjustments to get that "pop" back into the images... you should never go into a RAW converter thinking you are going to leave the image as the converter's default settings interpret it. David C.
| Latest registered member is Marcsaa 498 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
