Thread started 13 Dec 2007 (Thursday) 22:35
Skyport Help
John
Dec 13, 2007 22:35 |  #1
Received my Skyport kit today and trying to test it out but I am running into some problems. :oops:
1) The charger for the receiver, there are only two adapters for the outlet (one was already attached to the charger cord) both of them are not AC adapters. According to the picture in BH, it looks like I should have received the AC adapter for it.
2) I bought these PC-1 Miniphone to PC Cable cords (external link) to sync between the Skyport receiver and 580EX II. Is this the wrong sync cord? I can not for the life of me, trigger my 580EX II.
Any thoughts?
Thanks in advance.
john | gear | web hosting deal for POTN members!
FlashZebra
This space available
Dec 14, 2007 00:06 |  #2
I cannot quite comprehend the charger intrigue.
But, that sync cord should work.
Do you happen to have your 580EX set to Master-Manual mode. If so, that is the problem. The sync port is disabled in that mode.
Try another manual mode.
Enjoy! Lon
John
Dec 14, 2007 00:39 |  #3
FlashZebra wrote in post #4501723 (external link)
Hmm, nope. I also tried my SB-24.
Another weird thing I noticed was if I connect the flash units to the transmitter directly using the included Sub-Mini (2.5mm) to PC Sync Cord... if I hit "Test" the flash will fire but after that first fire, hitting "Test" again won't do anything AND none of the buttons on the flash respond. It'll go back to normal if I disconnect the PC sync cord from flash then back again. :cry:
Linkzi
Dec 14, 2007 00:57 |  #4
I just tested mine today without problems. My SB-28 and 26 worked fine in manual mode. I charged my receivers last night and had the US adaptor included.
Aloha,
Lincoln
"Be creative, don't make your photos look like everyone elses"
Eyes F20/40, Brain 5GB, Finger 20mm
John
Dec 14, 2007 01:03 |  #5
I got it to work... not sure what was wrong with it. Aside from the weirdness when connecting the transmitter directly to the flash, the main symptom was that it didn't look like the transmitter and receiver were 'connected'. I fidgeted around with the codes before and matched it to several different configurations without much luck.
About 5 minutes ago, I was fidgeting around with it again and they seem to be connected now as the transmitter is successfully triggering the flash. Weird but yay regardless.
Linkzi wrote in post #4501898 (external link)
...I charged my receivers last night and had the US adaptor included.
Thanks for confirming that Linkzi. Better call B&H tomorrow.
Thanks guys.
azpix
Dec 14, 2007 02:48 |  #6
aIpha wrote in post #4501287 (external link)
hopefully you have already resolved this. if not keep looking, its there. When i got my i went through the same shock. If i remember correctly, the AC plug has some sort of cover on it.
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
SkipD
Joined Dec 2002
Dec 14, 2007 06:23 |  #7
All of my Skyport receivers, whether in a kit with a transmitter or separate, came with a charger and three adapters for plugging the charger in to a wall receptacle. One of the three is for U.S.-style 120V receptacles, one is for the Great Britain style 250V receptacle, and the third will fit most other 240/250V receptacles found in other countries.
All three adapters are for AC power, by the way.
NONE of the adapters was connected to the charger if I recall correctly. You may have received a package that someone had played with. I would contact your vendor and get a replacement (or at least get the proper adapter that may be missing).
Skip Douglas
John
Dec 14, 2007 09:07 |  #8
SkipD wrote in post #4502601 (external link)
Yep, it came with only two adapters. :( The first thing I did was check the image that B&H has.
IMAGE: http://www.bhphotovideo.com/images/largeimages/505381.jpg
The adapters are pictured in the bottom-right hand corner. You see the 120V AC adapter attached to the plug. This is the one that I am missing. The one on the top was connected.
Funny thing is, there was a "was this opened before" clear and round sticker on the flap of the box that I had to rip to open the box. This sticker was intact when I opened the box. Did you guys have this sticker too? Maybe there are US versions and international versions...
MT ­ Stringer
Dec 14, 2007 09:14 |  #9
I got mine this past Tuesday and everything pictured above was in the box. However, the charger had the round two prong connector mounted on it. All I had to do was remove it and attach the one you would normally use for US houshold electrical recepticles.
Same goes for the second receiver. It had everything in the box also.
Good luck.
Mike
MaxPreps Profile (external link)
My Gear List
ben_r_
-POTN's Three legged Support-
Dec 14, 2007 09:14 |  #10
Oh wow, I didnt know that the Skyports had built in rechargeable batteries... So what do you do if they die in the field... Unless you carry a spare with you youre dead in the water. That would be a def advantage to going the pocket wizard route as at least you could replace the batteries.
azpix
Dec 14, 2007 20:01 |  #11
ben_r_ wrote in post #4503328 (external link)
for what it's worth, I got mine in September and and have shot about 300+ shots with them. Only charged them once when i first got them and they fire up no problem. I don't think they use a lot of battery power, but that just an assumption.
John
Dec 15, 2007 00:51 |  #12
B&H gave me an RMA and will be sending it back for an exchange.
Funny thing, my skyports are no longer working again. Same symptom as the one I described in the begging of this post. Does the receiver need to be fully charged in the beginning for this to work reliably? It turned on fine out of the box and since I don't have the 120V AC adapter, I can't recharge the receiver.
Hope this is just a defect and not something I will experience with the exchange.
SkipD
Joined Dec 2002
Dec 15, 2007 00:53 |  #13
aIpha wrote in post #4508032 (external link)
The receiver batteries are almost uncharged as delivered new. That's why you only got a few shots with the system.
Skip Douglas
John
Dec 15, 2007 00:57 |  #14
SkipD wrote in post #4508040 (external link)
Is there a way to tell that the receiver batteries are going low? I turn it on, it blinks twice then 4 seconds before it's lit very dimly then blink every few seconds.
SkipD
Joined Dec 2002
Dec 15, 2007 01:03 |  #15
aIpha wrote in post #4508050 (external link)
I don't know if there's a planned (by the manufacturer, that is) way to tell by looking at the LED, but it's obvious to me that if they stop working it's time to charge the receiver's battery and/or replace the battery in the transmitter :p.
Skip Douglas
2,707 views & 0 likes for this thread, 8 members have posted to it.
Skyport Help
1037 guests, 107 members online
