Thread started 14 Dec 2007 (Friday) 13:26
Post your 40D ISO 3200 shots!
djeuch
Dec 14, 2007 13:26 |  #1
I attended my 6-year-old son's Christmas play yesterday. Found that to get acceptable shutter speeds with my 70-200 f/2.8L IS, I had to bump to ISO 3200. Didn't want to do it, but I figured a noisy shot is still better than no shot at all.
I was impressed!
Not all images embedded, but links are there.
IMAGE: http://www.jeuch.com/pics/2007/2007-12-13/nomark/IMG_3832S.JPG
http://www.jeuch.com …2-13/nomark/IMG_3837S.JP​G (external link)
IMAGE: http://www.jeuch.com/pics/2007/2007-12-13/nomark/IMG_3843S.JPG
http://www.jeuch.com …2-13/nomark/IMG_3850S.JP​G (external link)
IMAGE: http://www.jeuch.com/pics/2007/2007-12-13/nomark/IMG_3871S.JPG
And then 2-pictures stitched together:
IMAGE: http://www.jeuch.com/pics/2007/2007-12-13/nomark/IMG_3833-3834.JPG
Canon 40D w/BG-E2N Battery Grip | Canon 5D w/BG-E4 Battery Grip | EF 70-200mm f/2.8L IS USM | EF 24-105mm f/4L IS USM | EF 85mm f/1.8 w/ET-65III | EF 50mm f/1.4 w/ES-71II | Canon 1.4x TC | Lowepro SlingShot 200 AW | B+W 77mm MRC (010) filter x2 | Speedlite 580EX II
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Dec 14, 2007 13:43 |  #2
I posted a 6400 and 3200 sample in my thread.
https://photography-on-the.net/forum/showthre​ad.php?t=418317
Remember posting a full size cropped down to 800 pixels or less won't prove any points about ISO noise, you have to view at 100% in your favorite photo program, then crop a small section out, and post those. You could probably shoot at 12800 and have the pictures look reasonable in their whole form resized down to fit the forum requirements.
Here are some other neat tests performed by others!
https://photography-on-the.net …416924&highligh​t=40d+3200
https://photography-on-the.net …arch.php?search​id=4040387
https://photography-on-the.net …411672&highligh​t=40d+3200
For Sale: Sigma USB Dock
djeuch
Dec 14, 2007 14:01 |  #3
TeamSpeed wrote in post #4504922 (external link)
Absolutely - web-sized will almost remove it all... but it's still amazing to me!
Here's the pano, un-resized (it's big!)
http://www.jeuch.com …rk/IMG_3833-3834-FULL.JPG (external link)
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Dec 14, 2007 15:07 |  #4
40D 3200 is very usuable definitely! Yes, that was quite large! ;)
Thank you for sharing, looks like a fun and cute presentation!
laxx
Dec 14, 2007 16:15 |  #5
You could easily manipulate the 2 pictures so all of the lines match up.
Crumpler 6 Million Dollar Home || Dakine Sequence
40D + BG-E2+ E1 Handstrap
580EX + Stofen || Lightsphere
Tamron SP AF 28-75mm f2.8 XR DI LD Aspherical (IF) Macro || Canon EF 70-200mm f4L USM || Canon EF 85mm f1.8 USM || Canon EF 70-200 f2.8L IS USM
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Dec 14, 2007 16:32 |  #6
I cropped the original pano jpg a bit, and took at a sliver to show your noise levels, along with some post-processing, just to show what can be done.
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Dec 14, 2007 16:34 |  #7
Final results, but sized down to 800.... yellow box is the crop. Again, at the normal family-printed sizes, you would never notice the post processing that took out some detail due to the noise, but there are options to take 40D high ISO and try to correct them a bit.
blackwell17
Dec 14, 2007 17:02 |  #8
did you use in-camera noise reduction for those original shots?
Nick
40D
- 50mm f/1.8 - 70-200L f/4 - 430ex w/ Gary Fong LS II
CyberPet
Hiding Under a Rock
Dec 14, 2007 17:04 |  #9
I posted this not long ago... ISO 3200.
I also wanted to test the noise on both the 30D and the 40D, so I shot the same setup at home.
30D full-res image (external link)
40D full-res image (external link)
Both camera are set to "Neutral" no Noise Reduction. They are intentionally a bit underexposed, to bring out more "noise". I also found a stuck pixel that I did later manage to remove by a great thread here. :) The difference in color might be due to sloppy set of custom white balance.
/Petra Hall
Click here to view my geeky gear list
I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink
djeuch
Dec 14, 2007 17:58 |  #10
blackwell17 wrote in post #4505992 (external link)
Nope... Wasn't planning for ISO 3200 and should have gotten that set up!
djeuch
Dec 14, 2007 17:58 |  #11
TeamSpeed wrote in post #4505803 (external link)
What did you use for the NR?
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Dec 14, 2007 18:00 |  #12
Noiseware pro, but noiseware community does the same thing and its free.
djeuch
Dec 14, 2007 18:22 |  #13
TeamSpeed wrote in post #4506323 (external link)
Thanks for the suggestion! (that's why we all love forums like POTN, right?
Here's the scaled down version and unresized version (the link) - original first, noiseware pro with more-or-less defaults
Original:
Unresized: http://www.jeuch.com …rk/IMG_3833-3834-FULL.JPG (external link)
Noiseware Community processed:
IMAGE: http://www.jeuch.com/pics/2007/2007-12-13/nomark/IMG_3833-3834-FULL_filteredS.JPG
Unresized: http://www.jeuch.com …33-3834-FULL_filtered.jpg (external link)
Even in the scaled down version, I can see a bit of a difference. At 50%, the quality is amazing. At 100%, though, it's obvious I was pushing everything to its limits!
Thanks again - I think I'll be noise-processing external to DPP from now on!
msowsun
"approx 8mm"
Gallery: 18 photos
Dec 14, 2007 20:04 |  #14
ISO 3200 is very useable and can really salvage bad lighting. (I also posted this on another thread) 40D and Canon 70-200 f/4.0 (200mm, 1/640 @ f/4.0)
I usually shoot Football at ISO 800, but it was getting dark so I needed to use ISO 3200. I didn't use the in camera noise reduction. I used "Noiseware"afterwards.
Straight from camera... No noise reduction:
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/Canon%2040D/IMG_4836a.jpg
After "Noiseware" Noise Reduction:
IMAGE: http://i2.photobucket.com/albums/y17/msowsun/Canon%2040D/IMG_4836a_filtered.jpg
Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
blackwell17
Dec 15, 2007 00:11 |  #15
after the Noiseware reduction, did you go back in and sharpen?
Sorry for all the questions, just trying to learn as I just got my 40D and love the high ISO/low noise factor!
Nick
40D
17,368 views & 0 likes for this thread
Latest registered member is shuadchaun
944 guests, 278 members online
