I've played with ETTL master/slave setup a bit, and found the following things. I just want to confirm my findings are correct.
1) when I set master to not-firing, it still fires, in both the preflash and actually shot. I set things to exposure to manual, took a shot with flash completely turn off, and with master turned on (slave turned off) and set to not fire, the exposure is different. the one with flash turned off is pitch black, the one with master "nont-firing" is underexposed about 1.5 stop
2) if I set ratio to 1:4, and FEC on camera to 0. that means the master will expose the foreground properly, and slave will be four times as powerful, and will therefore overexpose? I can't seem to get consistent result in this test.
3) Is there a way to make use of the external flashes focus assist beam without letting it flash at all?
