Thread started 16 Dec 2007 (Sunday) 09:48
Waterproofness of Tamrac series backpacks
jeetsukumaran
Dec 16, 2007 09:48 |  #1
Still looking for a small camera backpack that fits my needs. I was considering the Micro Trekker 200, but there's no inherent rain protection. The Tamrac Expedition 4 is comparable in size, and the Tamrac site says that its material is waterproof except for the zippers, but a rain flap takes care of that. Has anyone got any of the Tamrac bags and can verify its waterproofness? Something that will survive a full monsoonal downpour for a few hours or more?
Gallery: http://www.flickr.com/​photos/jeetsukumaran/ (external link) Website: http://jeetworks.org/ (external link) Canon 6D, Zeiss Distagon T* 2.8/21, EF 24-70 f/2.8L II USM, EF 40mm f/2.8 STM, EF 100mm f/2.8 Macro USM, EF 100-400mm f/4.5-5.6L IS USM II.
Anke
Dec 17, 2007 01:05 |  #2
I have a Tamrac Expedition 5. I haven't exactly been in a full monsoon but its very good in typical British weather, which is usually rain. Apparently it floats too.
Anke
showngo
Dec 17, 2007 11:22 |  #3
I have the Tamrac Adventurer 9 not sure how it compares, but it is NOT waterproof. I was in heavy rains when in Japan, and under and Umbrellla 60% of the time. The bag was soaked on the outside and very moist inside.
Ben
My Gear (external link)
jeetsukumaran
Dec 17, 2007 14:57 |  #4
Thanks all. Encouraging news from Anke, but discourging news from Ben! I'm planning to get the Expedition 4, which is too small for the Tamrac rain covers. Anyone know where I can get a small enough rain cover for this pack?
showngo
Dec 17, 2007 15:11 |  #5
I am going to spray mine with waterproofing stuff from REI. But for rain covers I would figure out your backpack's dimensions and look on REI for North Face (and other brands) rain covers for those packs that are roughly the same size.
If you are going to be in that much rain have you looked at the Lowepro Dryzone packs?
Ben
jeetsukumaran
Dec 17, 2007 17:55 |  #6
Ben:
I already have the Nature Trekker AW II, which works fine in the heaviest rain storms and a range of other camera-unfriendly weather. I was looking for a light-weight day-trip solution that would hold up if I happened to get caught by an unexpected shower.
I've been looking at rain covers, but the smallest is over 1000 cu inches in capacity, twice as large as the Exp 4.
showngo
Dec 17, 2007 18:11 |  #7
I see, I thought this would be your only pack. This is not as clean of a solution, nor would it be the one that I would look for but none the less. You could always just take a garbage back with you, cut holes where needed for a quick rain cover... again not ideal but if it is only for the just in case scenario it would work, and take up much less space.
Ben
showngo
Dec 17, 2007 18:13 |  #8
Also just using waterproofing spray may do the job. I will spray mine tonight and I can let you know how it works tomorrow night. It takes about that long to dry completely.
Ben
jeetsukumaran
Dec 17, 2007 21:24 |  #9
Thanks, Ben. Really looking forward to your results. How do you plan to test it? Stick it under the shower for a while?
andrewhuxman
Dec 18, 2007 09:31 |  #10
I have the Expedition 9 and it works well in moist enviornments. I have had it rained on it held its own but I wouldnt toss it in the river to see if it floats.I dont purposely put it in the rain but feel confident that it will do alright in case you get caught in a storm.
A little L goes a long way.
jeetsukumaran
Dec 20, 2007 09:55 |  #11
Thanks Andrew, that's reassuring. Ben---how did the tests go?
showngo
Dec 20, 2007 10:18 |  #12
Sorry I forgot (busy wrapping presents). After I sprayed the water proofer on the bag I stuck a bunch of dry paper towels inside and tossed it in the shower for a little bit. Not ideal testing but it gets the job done. The bag repelled the water fine, but the zippers are not sealed so those let in water/moisture. Also the section of the bag that is against your back is very porous and does not seem to have sealed well. Overall I would now feel comfortable taking the bag in light rain for a short period of time. I would have no hesitation taking it on a hike if it was not forecasted to rain, if rain is known I still would not take it out. Hope that helps!
Ben
jeetsukumaran
Dec 20, 2007 10:25 |  #13
Ben:
Great test! At least we know the weak points now---the zippers and the back. I think the Expedition series bags have rain flaps to protect the zippers, but it's up to your back/body to protect the back of the bag. Very, very useful to know. Thanks for testing, and thanks for reporting the results.
jeetsukumaran
Dec 22, 2007 20:08 |  #14
An update. I just got the Tamrac Expedition 4. I did pretty much the same thing Ben did, i.e., stuffing all the pockets with paper towels, and left it running under a full shower for quite a while. I did *not* pre-treat the bag with waterproofing spray, but I did cinch down the rain flap tight.
The result?
The outer wing pockets got soaked. Totally.
The full-sized outer pocket let in some water from the top, and the top half of the towels were damp, as well as the bottom corners. I estimate about 70% of the volume of towels remained dry.
I think that the weak point in both the above cases is the zippers. While these are weather sealed, the gap where the zippers meet lets in the water.
The main camera compartment was pretty damp, and some of the sections had collected pools of water. But it appears that all the water came in from the *back*---through the seams where back of pack joins the sides to be exact. No water came in through the front of the pack---the rain flap did its job.
All in all, then, these results reaffirm the findings of Ben: the weak-points are the zippers and the back. While wearing the backpack in the field, I guess your body would protect the back somewhat (as long as the backpack is cinched tight against it), but a rain cover or something might be needed to protect the outer compartments. As I've mentioned, the Nature Trekker AW II has held up in torrential monsoonal downpours for several hours, and so perhaps its design, with the built-in rain cover might be better. The DryZone waterproofness sounds great (at the cost of greatly increased bulkiness), but while it deals with water really well, its zippers seem vulnerable to the other elements of the field, i.e., mud, sand, and dust, and require some maintenance in unfavourable conditions (see: http://www.f-8andbethere.com/tips/d​ryzone.htm (external link)).
Anke
Dec 22, 2007 20:19 |  #15
jeetsukumaran wrote in post #4554410 (external link)
The result?
All in all, then, these results reaffirm the findings of Ben: the weak-points are the zippers and the back. While wearing the backpack in the field, I guess your body would protect the back somewhat (as long as the backpack is cinched tight against it), but a rain cover or something might be needed to protect the outer compartments. As I've mentioned, the Nature Trekker AW II has held up in torrential monsoonal downpours for several hours, and so perhaps its design, with the built-in rain cover might be better. The DryZone waterproofness sounds great (at the cost of greatly increased bulkiness), but while it deals with water really well, its zippers seem vulnerable to the other elements of the field, i.e., mud, sand, and dust, and require some maintenance in unfavourable conditions (see: http://www.f-8andbethere.com/tips/d​ryzone.htm). (external link)
Thanks a lot of this, this is a very useful test. Kudos for doing it to a brand new bag.
Anke
3,966 views & 0 likes for this thread, 10 members have posted to it.
660 guests, 120 members online
