Thread started 16 Dec 2007 (Sunday) 17:18
Aperture export question
spphoto
Dec 16, 2007 17:18 |  #1
I've been using Aperture for just under a year and love it, it's totally redone my workflow to be so much better and more productive. I have run into a question finally that I haven't been able to figure out myself.
I have a series of photos I would like to export into folders according to a metadata field I've set (and need to keep for another part of my workflow). When I export I can set the folders to be anything from times and dates and all sorts of great stuff, but I can't figure out how to make one where I can choose a metadata tag. The one I need is "Special Instructions". I can do it manually, but we're talking about 500-750 photos at a time, and it would be a lot easier if Aperture could make those folders for me.
Any other secret tricks you may know are appreciated too!
~ Stefanie Pletscher
www.spphoto.ca (external link)
Tony-S
Dec 16, 2007 18:10 |  #2
Hmm. Never had to do that before. Can you search by the meta data of your criteria, then select all and export into a folder, then repeat for the other data types? Good luck, and if you find a solution be sure to post it here for the rest of us. We appreciate your suffering.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
spphoto
Dec 16, 2007 18:31 |  #3
I could do that, but it would be even more work as sorting them manually after, as there are generally only about 5-7 photos per folder.
naryab
Dec 19, 2007 11:35 |  #4
How about a smart album based on the IPTC data? You can choose the Special Instructions there. Then export the smart folders as Tony-S recommended. Just a thought.
1,279 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is josetide
1053 guests, 170 members online
