I get an error message that my monitor resolution is not sufficient. The instruction manual doesn't cover this problem. What do I do now? (I have a PowerShot A460.)
DavidLewis Hatchling 1 post Joined Dec 2007 Location: Orlando FL 32806 More info | Dec 20, 2007 18:04 | #1 I get an error message that my monitor resolution is not sufficient. The instruction manual doesn't cover this problem. What do I do now? (I have a PowerShot A460.)
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Dec 21, 2007 07:01 | #2 What resolution is your monitor set to? What resolutions does your graphic card support? The obvious solution would be to run your graphics card at something like 1280x1024 or better, if supported. Jon
[default] Member 60 posts Joined Aug 2007 Location: Chesapeake, VA More info | Your monitor res is probably at 800x600. The installer won't run at that low of a resolution. It needs to be 1024x768 minimum. 20D - EF-S 10-22mm and EF 70-300mm
okh66 Hatchling 3 posts Joined Apr 2011 More info | Apr 15, 2011 01:16 | #4 David Lewis wrote in post #4543113 I get an error message that my monitor resolution is not sufficient. The instruction manual doesn't cover this problem. What do I do now? (I have a PowerShot A460.) • just untick control panel->display->montor->advanc¬ed->monitor->hide modes
thejimmy Goldmember 1,426 posts Likes: 33 Joined Dec 2009 Location: west coast of Florida More info | Apr 16, 2011 12:36 | #5 okh66 wrote in post #12225728 • just untick control panel->display->montor->advanc¬ed->monitor->hide modes or use external monitor I hope their not still looking for an answer after 3.5 years!
tmwag Brown Noser has crush on Suzyview More info | Apr 17, 2011 14:56 | #6 the jimmy wrote in post #12234247 I hope their not still looking for an answer after 3.5 years! Good Point
| Latest registered member is Thunderstream 1620 guests, 100 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
