Well, today my Sunpak TR-Pak II battery pack was delivered and boy is it ever awesome! I was able to shoot 10 full powered flashes in 10 seconds (just to test of course). No more worrying about missing a shot because of flash not firing or annoying my fiance waiting for the flash to recycle. So I'm a pretty happy camper
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
But of course it doesn't come without questions...
(1) *** never mind on this one
*** the battery pack works with one of my 383 flashes (its actually badged as a Quantaray Q383 Super), but not on the other (a Sunpak Auto 383 Super). They are identical in every way except the badging, but with one it doesn't give power at all(2) with the one that works, it seems to always fire at full power. I tried setting the flash to 1/16th power and firing, both with Test button as well as through wireless triggers but the power is always at full blast
Anyone have any experience with either of these?
All I did was disconnect the chord and adapter from the TR-Pak and reconnect. Might have been a slightly loose connector or something, but it works! Now if I could only figure out the power setting issue...
I'm figuring I need to set it on the 10 volt range under the DC voltage section, but I'm not sure. Does this look right? If it is, when I'm touching the contacts, the needle barely moves at all. I've also tried firing the flash with the test button while touching the contacts. Still nothing...
