What I mean is I see a 50/1.8 is 75$ or so but the Canon 50/2.5 Macro is 240$ +. What I like to know is what is the difference there? What makes a lens a macro.
slimninj4 Goldmember 1,151 posts Likes: 7 Joined Jun 2007 More info | Dec 24, 2007 08:00 | #1 What I mean is I see a 50/1.8 is 75$ or so but the Canon 50/2.5 Macro is 240$ +. What I like to know is what is the difference there? What makes a lens a macro. Canon 40D 5Dm3 || 24-70 L 70-200 2.8 IS2 100mm Macro 50mm 1.8 35 1.4
JeffreyG "my bits and pieces are all hard" More info | Dec 24, 2007 08:12 | #2 The minimum focus distance is the main difference. The 50 CM can get close enough to the subject that it will appear at 1/2 life size on the sensor. Put another way, you can fill the entire frame of a picture with something about the size of a quarter. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Dec 24, 2007 10:42 | #3 JeffreyG wrote in post #4561673 The minimum focus distance is the main difference. The 50 CM can get close enough to the subject that it will appear at 1/2 life size on the sensor. Put another way, you can fill the entire frame of a picture with something about the size of a quarter. The 50/1.8 is not a macro and cannot focus close enough to anything to make it appear at more than about 1/5 life size on the sensor. This would mean filling the frame with something perhaps the size of a softball. The other differences are more subtle, the 50CM has a very flat plane of focus so that it can be used to take pictures of documents (reproduction work) though flat scanners have made that a little needed use. Good description...though I'd add that the term MACRO strictly applies to lenses whose image is LIFESIZE and this "macro" is only .5 LS...but for general closups it'll do... My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Dec 24, 2007 11:54 | #4 The classic definition of Macro is an area where the image size is from 1/4 to 2x life size. In others words, the subject (that fills the frame) is from 4" x 6" down to 1/2" x 3/4". Smaller is another area of photography. Larger most lenses/cameras already do. GEAR LIST
CanonBob Goldmember 2,063 posts Likes: 52 Joined May 2007 Location: Poitou-Charentes, France More info | Dec 24, 2007 16:18 | #5 kitacanon wrote in post #4562333 Good description...though I'd add that the term MACRO strictly applies to lenses whose image is LIFESIZE and this "macro" is only .5 LS...but for general closups it'll do... Also...the "CM" has a metal mount like the 50/1.8 MKI and like that oldie, it has the old buzzy AF motor...the MKII has a plastic mount BUT the more modern, quiet motor, which some people claim is not as good as the older one...just quieter....When I got the CM I sold my MKI as I have the 35/2 (again with the buzzer) and that covers my need for low light shooting, and the CM is a VERY nice portrait lens and landscape lens (yes a bit longish, but great for longer landscape shots)... It's worth adding that the Life Size Converter was marketed to turn the 50CM into a true macro lens. The LSC also works with many other lenses (not to 1:1 though). It's basically an extension tube and T/C rolled into one. 1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Dec 24, 2007 16:27 | #6 Yes...should have mentioned the converter/tubes.... My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
| Latest registered member is semonsters 894 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
