Thread started 24 Dec 2007 (Monday) 23:11
Low cost off camera flash tutorial for beginners
Axton
Dec 24, 2007 23:11 |  #1
I've just begun my foray into off camera flash and I'm posting this for those who want to start a small portrait studio. If you are a pro, you'll probably waste your time reading this as it is intended for beginners that are confused as to what to buy & how to use it.
I recently posted a DIY home studio tutorial with a cheap, inexpensive hot light set up. After hearing too many comments like, "man, it's hot in here!" and trying to get my clients not squint, I decided it was time for a portable off camera flash set up...
So, here is a detailed description of my set up. Mind you, this is only one way to go. There are many others, but I hope this helps the confused beginners (like I was)...
At the end of this post I will provide links to the all of the items I bought for this set up and the total cost.
1) The following few pics are the main ingredients to my off camera flash set up.
2)
3)
4)
5)
This a DIY reflector that cost about a buck. It is two pieces of card board taped together and covered with gold wrapping paper from the Dollar Store (I have another with silver wrapping paper).
The black stand you see is the bottom of a guitar stand (I'm a musician so I had it laying around, although they're cheap any way, about $10). 1/2 inch PVC fits perfectly into these stands, so you can make the stand as tall as you like.
I just slide the PVC inbetween the two layers of cardboard and adjust the height with a cheap clamp, as shown.
6)
7) Here is the full set up:
It's a s simple as this:
Camera > hotshoe adapter 1 > extension sync cord > Hotshoe adapter 2 >Main flash.
The secondary flash fires automatically because it is attached to an optical slave hotshoe adapter (when the main flash fires, this optical sensor sees the light, and automatiocally fires the second flash).
Here is what I purchaesed:
Hama PC sync extension cord (external link) $9.95
Hama Hotshoe adapter 2 (external link) $16.95
Hama Hotshoe adapter 1 (external link) $14.95
Photogenic Eclipse 45" Umbrella (external link) $28.50
Impact Umbrella Bracket (external link) $13.95
Impact 6 foot stand (external link) $19.95
Optical Slave Flash Trigger (external link) $13.00 including shipping
Sunpack 383 I bought of eBay and it came with a Stofen Diffuser. $60. You can get them from B&H Photo brand new for $80 bucks.
The sunpak 322D I had in the closet from when I was using an Olympus OM10! (Any flash with a Manual setting will do here).
I have purchaesed the eBay Cactus wireless trigger but it is still in transit, so I can't comment on it yet. I have read however that it's a good idea to have sync cables as a backup in case the wireless bugs out.
This cost a total of ~$170.00. It is a fantastic portable set up! This little bit of equipment will let you get as creative as you want with your portraiture without breaking your piggy bank.
Example shot. Secondary flash pointed at subject's back. No reflector. Main light uppr camera left.
I hope this sheds some light on how to get started with off camera flash. I'm having ton's of fun! I have a shoot scheduled Christmas day and it will be my first time taking my set up in the field! Dang, better charge my batteries...
Thanks to all who provide endless knowledge to this forum everyday (especially you, Curtis - you've been a wealth of help!). Without which, I would not have advanced as quickly as I feel I have in understanding some key aspects of photography. I THANK YOU!!
wishboxphoto (external link) | blog (external link)
inernets
Dec 24, 2007 23:18 |  #2
Wow great post.. i was just considering setting up a studio with "hot lights" and i saw your earlier tutorial and liked it, but i didnt hear the complaints about the heat. Great tutorial, this should be stickied!
edit: You know, i would really like to see what you could with one more light added into the equation. I am not requesting this from you, because you spent alot of time on this and this is the first replay, but with that being said that was awesome and i do truely appreciate it!
1D III - 1D II - 5D II - 50D - 40D - EOS M.
16-35mm, 24-105mm, 100-400mm, 40mm 2.8, 50mm 1.4, 85mm 1.8, 135mm 2.0 . 1.4x III, 2x III. 270ex, 270exII, 430ex, 600ex
Axton
Dec 24, 2007 23:22 |  #3
inernets wrote in post #4565192 (external link)
Yeah, the hot light set up is FANTASTIC for learning portraiture. If you have Family, friends, etc, to practice on, it's awesome. However, with a paying customer, it can be uncomfortable for them. It has provided me with a great learning environment and I feel I'm ready to move to off camera flash ( a WHOLE NEW WORLD!).
Axton
Dec 24, 2007 23:29 |  #4
I honestly don't think I need another light right now. 2 lights & a reflector seem like enough. There are endless combinations/angles I can use to achieve varied effects. I want to exhaust this set up before I move on to more complicated things...
e ­ r ­ y ­ k
Dec 24, 2007 23:35 |  #5
beautiful write up! i recently got into the flash world, but i opted to go with a 580ex and a 430ex... granted theyre great, but i think youre method woulda saved me quite a bit of financial pain and suffering :P
Canon EOS 5Dmk3 //
inernets
Dec 24, 2007 23:44 as a reply to  @ e r y k's post |  #6
yeah, i was hesitant on doing a flash setup because i was assuming i should buy a couple of 580's, but they are way too expansive. If i can get a couple for 80 each, i will deffinitly pick that up to just get the hang of it all.
Axton
Dec 24, 2007 23:54 |  #7
inernets wrote in post #4565276 (external link)
I agree. My Sunpack 383 won't "talk to" my XTi, but it's an awesome flash & I don't mind going manual. I'm a noobie with a captal "N" and I feel that until I know what I want to achieve with my portraiture, it's better to learn at low cost.
Before dropping major $$'s on Alien Bees, etc., put your subject in front of a window (the sun is free) and get comfortable posing them and taking a quality portrait. Until I can be confident that I can get a personality out of my subject and portray them truthfully in a photograph, I feel I can't justify spending lots of hard earned money on equipment. If money is no object, then more power to you! Just know that a good artist can make something beautiful out of nothing, even a cardboard disposable camera.
inernets
Dec 25, 2007 00:02 as a reply to  @ Axton's post |  #8
I totally agree with you, you have a great way of thinking about not only photography, but a good way of learning how to do ANYTHING. Start out with the basics, slowly move your way up and when the skill is there, you can undoubtly go for the upgrades.
I do have the money to buy all of the great equiptment, but i dont want to spend thousands of dollars on a crap load of equiptment that i have no idea how to properly use and probably will just give up out of frustration.
Thanks again Axton!
claybuster
Dec 25, 2007 07:09 |  #9
Thanks Axton! Great post! Could you tell us about the flash settings please ? Also looking at the umbrella it looks like the inside center is flat ,not curved like the outside . Does it have some sort of secondary cover or baffle?
Mike
MY GEAR
Whatever you are, be a good one- Abraham Lincoln
Axton
Dec 25, 2007 12:37 |  #10
claybuster wrote in post #4566010 (external link)
Mike
Flash settings vary depending on the effect I want. Main flash is usually set to 1/2 power and background flash is at full or 1/8 (the only two settings it has).
The umbrella has no baffles/etc. It is a little flat in the center, I'm assuming to help when it is being used as a reflector.
e ­ r ­ y ­ k
Dec 25, 2007 12:41 |  #11
Axton wrote in post #4565299 (external link)
this is so true for all aspects of photography, not just lighting.
nothing bothers me more than reading someones thread, then looking at their gear list and wondering... what are they doing with that high caliber of gear if they cant even figure out the simplest of things...
Canon EOS 5Dmk3 //
claybuster
Dec 25, 2007 13:02 |  #12
Axton wrote in post #4566962 (external link)
Were these the flash settings you used for the sample picture you posted?
Mike
MY GEAR
Davidoff
Dec 25, 2007 14:37 as a reply to  @ claybuster's post |  #13
Good post ! Could you elaborate on the difference between using the brolly to bounce or shooting through it ?
My website (external link)
My Facebook (external link)
500px (external link)
yendikeno
Gallery: 24 photos
Dec 25, 2007 18:25 as a reply to  @ Davidoff's post |  #14
Thank you for posting this, as I am your target audience; i.e., a flash newbie. Very well written and illustrated.
_____________
Regards,
AZFred
claybuster
Dec 25, 2007 19:31 |  #15
The more I look at that umbrella the more I like it. I like the way it flattens out inside toward the center,kinda looks like a octabox or something. I think I'll order one.
Mike
MY GEAR
21,920 views & 0 likes for this thread, 24 members have posted to it.
Latest registered member is reverse222
489 guests, 127 members online
