Hi All,
I'm hoping somebody can shed some light on this. I received an 580EX II for Christmas (lucky boy!) and in general it works well. However there is a really weird problem that happens intermittently. It has happened on four separate occasions now. The flash occasionally goes off all by itself. I definitely didn't depress the shutter or pilot light!!!
The first time it happened, I had just taken a shot and was lowering the camera, and suddenly the flash output another flash. The second/third occurrence was then same scenario. On fourth occassion, the flash fired three times while I was adjusting the head!? Again, no fingers anywhere near the pilot/shutter buttons! Just after it had fired 3 times, I tried pressing the pilot light to fire manually, thinking the button might be "stuck down", alas the flash wouldn't fire at all. It was like the capacitor had discharged during the random firing, even though the pilot light was red, indicating full charge.
I'm trying to work out if the problem only occurs when the flash is on the camera (350D). So far I haven't been able to reproduce the problem when the flash is unmounted, but then it has only happened intermittently so it's hard to reproduce at all, let alone on the camera or off camera. It's almost like something is shorting inside the unit causing it to fire randomly, but its so hard to reliably reproduce the issue.
Does this sound dodgy.. I tried googling but there doesn't seem to be many instances of this on the net.
Any thoughts would be greatly appreciated!!
