Has anyone upgraded to SP2 yet and, if so, does it impact on using CS? I'm a bit cautious about applying the upgrade until the obvious bugs have been worked out.
BoySpot Senior Member 492 posts Likes: 5 Joined Feb 2004 Location: Chicago IL More info | Sep 14, 2004 16:23 | #1 Has anyone upgraded to SP2 yet and, if so, does it impact on using CS? I'm a bit cautious about applying the upgrade until the obvious bugs have been worked out.
gmitchel Senior Member 306 posts Joined Oct 2002 Location: Tallahassee, FL More info | Sep 14, 2004 18:49 | #2 Permanent banThe only issue I've had so far is with the Help system. Each tiome you invoke Help, you have to unblock an active component. Otherwise the Topic outline is not indented.
iof Senior Member 428 posts Joined Mar 2004 Location: Nebraska More info | Sep 14, 2004 18:59 | #3 If you have an A4Tech wireless USB mouse I suggest you defer installing SP2 or consider replacing the mouse. The mouse driver does not play well with SP2 and will repeatedly crash windows untill you unplug the mouse receiver. A4Tech tells me they will have a new compatable driver out in "a couple months". Ron.
psk4363 Senior Member 720 posts Joined Jun 2003 Location: Bolton, UK More info | Sep 15, 2004 06:28 | #4 I upgraded Win XP Pro to SP2 a couple of weeks ago and have had no problems whatsoever with PS CS. A little G9
chris.bailey Goldmember 2,061 posts Joined Jul 2003 Location: Norwich, Norfolk, UK More info | Sep 16, 2004 01:40 | #5 No problems here though I admit to spending the whole install time with my fingers crossed
| Latest registered member is Thunderstream 1209 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
