Thread started 28 Dec 2007 (Friday) 08:36
How big of an umbrella?
John ­ E
Dec 28, 2007 08:36 |  #1
How big of an umbrella is practical when using a 580 or 430 ex off camera on a light stand as the main or key light? In other words, even if I pull out the flash diffuser panel, can the flash cover the wide area of a large umbrella or is there just a big hot-spot in the middle?
Currently I have the Impact "kit" umbrellas which are smaill - I believe around 32". I can move them in close to the subject but was wondering if I would benefit from a larger umbrella.
Thanks for your advice.
John Elser
Canon 5D MK II; 30D; EF 85 f/1.8; EF 70-200L f/2.8 IS II; EF 24-105L f/4; EF 135L f/2; EF 24-70L; Canon 580 EX II(x3).
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Dec 28, 2007 09:55 |  #2
Depends. The larger the area of the subject you want to cover evenly, the more important a larger umbrella is. You decide.
Wilt
Dec 28, 2007 10:04 |  #3
Assuming 28mm (FF) coverage setting on the flash, it covers 25" x 37" dimension at a distance of 30" from the umbrella material. At 50" away from the material, it would cover 42" x 63" dimensions. Of course, the lighted area is actually larger than the dimension stated (which is a lens FOV). Use a program like f/calc which computes lens FL coverage FOV to give you an idea of what area can be filled
Mark-B
Dec 28, 2007 10:40 |  #4
The biggest I have used is 45". This works easily without the diffusion panel pulled down. I probably wouldn't go any bigger than this.
Mark-B
msbphoto.comexternal link
ben_r_
-POTN's Three legged Support-
Dec 28, 2007 13:40 |  #5
I use 43" umbrellas for my 580EX II flashes. Work great for everything I have tried them with so far.
Atomic79
Dec 28, 2007 14:12 |  #6
From what I can tell Zack Arias over at OneLightWorkshop (external link) regularly uses a Vivatar 285 with a 60" so I don't think it would be a problem with either of the Canon units. As Wilt commented I don't know if it will fill the umbrella but it should be close, they won't fill a ceiling either but you still use bounce flash. As Frank said if the subject requires a larger light then go for it. For the most part an umbrella is a pretty cheap add on that just gives you an extra tool in the bag.
No matter how slow the film, Spirit always stands still long enough for the photographer It has chosen. Minor White
966 views & 0 likes for this thread, 6 members have posted to it.
499 guests, 126 members online
