Ok I have
Adidt remote cable w/ 3/32 stereo jack
3/32 stereo plug (which I can use on my 300D or plug into the Adidt remote)
1/8 mono plug for skyport receiver
I have identified which wire is which on the 3/32 stereo plug (one each for half-press, full-press and a common ground)
What I need to know is how to connect them to the 1/8 plug.
(with a soldering gun, dumbarse!)
Ok I know that much.
It seems the camera will fire simply by grounding the wire for full press without touching the wire for half-press. But I have heard about also grounding the half-press wire to "keep the camera awake" or something like that.
I do want to be able to use the remote camera in Av or Tv mode so that it meters each shot in changing conditions, if that makes a difference.
Any instruction or explanation would be greatly appreciated.
Edit: If you want to skip the confusion and go right to my conclusion, go to post #20.
Take a look at your diagram. in one, you have the tip as the shutter. And in the other, you have the tip as focus.
) work!!.
