Thread started 29 Dec 2007 (Saturday) 01:46
Strawberry.. what am I doing wrong?
xa-coupe
Dec 29, 2007 01:46 |  #1
I have been lurking a while and decided to take the plunge and spend $20 on some ebay extension tubes. I wanted to try the whole thing before I spent serious bucks on decent tubes or a dedicated macro.
My first problem is lack of clarity. I just can't seem to get a pin sharp focus even with a f1.4 50mm and the rate times I manage the DOF is less than a mm.
Anyway.. I struck an interesting issue with a strawberry. After seeing someone do a great pic I thought I would give it a go.
I had a light above and to the left and a flash unit above and to the right yet no matter which lens I use I get a big black band on the bottom like this :
As soon as I turn the flash off it goes away. There is no obstruction on the bottom and if I take a ( out of focus ) pic of something further away it's not there. Why is it so ?
Gear List:
Bodies:R, 6D, 1500D plus an Astro Camera
Lenses: A few L,
::John::
Gallery: 60 photos
Dec 29, 2007 02:27 |  #2
Your shutter speed (1/320") is too high for your flash?
Try dropping it down to 1/250" or 1/200"
I am the proud owner of the Peleng 8mm Fisheye lens
xa-coupe
Dec 29, 2007 02:31 |  #3
that's it !! I guess the light was still moving. Now I have to stop it over exposing but thanks for the tip !
edit :It's a tiny DOF but at least it can be seen now !
Gear List:
Lenses: A few L,
LordV
Dec 29, 2007 02:54 |  #4
If you attach the 50mm lens normally to the camera first set the aperture to say F8 or F11, depress the DOF preview button and remove the lens whilst keeping the button depressed then the lens will stay stopped down when you then attach it to the ext tubes (problem with the cheap tubes is no aperture control). You will end up with a dimmer viewfinder but considerably more DOF.
Brian V.
Macro Hints and tips
halesowenkid
Dec 29, 2007 03:04 as a reply to  @ LordV's post |  #5
Have a look at this link by Waleed
https://photography-on-the.net …4112&highlight=​strawberry
Mike
"One precious moment captured in time"
Canon EOS 30D + BG-E2 Grip/Canon EF-S 17-85mm/Canon EF 50mm/Sigma 10-20mm DC HSM/Sigma 70-300mm APO Macro DG/Accessories
xa-coupe
Dec 29, 2007 03:11 |  #6
LordV wrote in post #4587837 (external link)
Brian V.
ahh, this answers another question I had. I knew that the cheap tubes had no control but even if I set it for F22 I got the same DOF, I figured it might have something to do with tubes... thank you.
https://photography-on-the.net/forum/...ght=s​trawberry
excellent, thanks !
Gear List:
Lenses: A few L,
xa-coupe
Dec 29, 2007 03:25 as a reply to  @ xa-coupe's post |  #7
Brian, you have managed to fix my main issue .. this is a quickie but all of a sudden I am off and running ... thanks again !
Gear List:
Lenses: A few L,
xa-coupe
Dec 29, 2007 03:47 as a reply to  @ xa-coupe's post |  #8
My last strawberry pic, I promise !
Gear List:
Lenses: A few L,
macro ­ junkie
Dec 29, 2007 04:54 |  #9
xa-coupe wrote in post #4587966 (external link)
much better..well done../now show us some insects..:p
Uk prayingmantis forum - http://www.dragonscres​t.co.uk/forums/index.p​hp (external link)
My flickr gallery -http://www.flickr.com/​photos/hooked_on_macro​/ (external link)
DA Gallery where i sell prints - http://macrojunkie.dev​iantart.com/ (external link)
MPE-65MM - MT-24EX Twin Macro Flash (diffused with 2 X Gary Fong Puffer diffuser)
EF-S 60mm f2.8 USM - 430ex (diffused with lumeriqest soft box)
xa-coupe
Dec 29, 2007 05:00 |  #10
macro junkie wrote in post #4588101 (external link)
I'll find some tomorrow .. it's dark out now :oops:
Gear List:
Lenses: A few L,
macro ­ junkie
Dec 29, 2007 06:23 |  #11
xa-coupe wrote in post #4588118 (external link)
use a torch..heheheh im joking
S7000
My brain hurts
Dec 29, 2007 22:45 |  #12
macro junkie wrote in post #4588289 (external link)
No you weren't. :p
xa-coupe
Dec 29, 2007 22:48 |  #13
S7000 wrote in post #4592879 (external link)
No you weren't. :p
I'm scared of the dark so it was never going to happen :)
one little bugger that stood still...... Had to crop it down a bit otherwise he was a little lost in the pic.
Gear List:
Lenses: A few L,
Glenn ­ NK
Dec 30, 2007 12:11 |  #14
Now, if you really want to get into the macro "bug", take a look at Brian's tutorials:
http://www.dgrin.com/s​howthread.php?t=50752 (external link)
And acquaint yourself with focus stacking (if you haven't already):
http://hadleyweb.pwp.b​lueyonder.co.uk/CZM/Ne​ws.htm (external link)
When did voluptuous become voluminous?
xa-coupe
Dec 30, 2007 21:13 |  #15
Great links, thanks Glenn !
Gear List:
Lenses: A few L,
2,167 views & 0 likes for this thread, 7 members have posted to it.
1080 guests, 115 members online
