Thread started 16 Sep 2004 (Thursday) 13:17
Panorama using PhotoStitch
Claire
Ikea Wannabee
Joined Jan 2004
Sep 16, 2004 13:17 |  #1
Today I bought myself a small tripod (Velbon 660( for the curious). Thought I'd try it out and at the same time give PhotoStitch a try.
Now, after the software has merged the photos you can still see a bit of a line where it's been merged together. Does anyone have any good tips on how to make that merging place less visible? So that it blends together better.
/Claire
My Photo Website - (external link) | My Flickr gallery (external link) | Photography Blog (external link) | My Twitter account (external link) | Become a Fan on Facebook (external link)
"You too, could easily look like that if you had a squad of mad geeks fussing over you with retouching software"
awagner
Joined May 2004
Sep 16, 2004 14:18 |  #2
Here is a way its more work but gives way better results
In Photoshop
Create yourself a new file (make it a bit to big you will crop after)
Open all your pictures and drag them in that new file, they will appear as different layers
Arrange your layers in order (from left to righ or vice versa) (they should appear one over the other one)
superimpose your pictures (using the layer opacity at 50 to 60% so the merge on each other okay)
When your done you should have your panorama but with highly visible lines.
(make sure all your layers are at 100% opacity)
now the fun part starts
With the erase tool (e) at anywere between 30 to 50% , select the second lowest layer (the one thats above the lowest one) start erasing the lines.
when your done crop and save (actually save as you go!)
Layer after layer it should work, as long as things or people did not move, as your were taking the picture
tips: take vertical pictures you will have less problem merging them and will have more picutres to work with (get rid of the curving effect of the lenses ; barrel distortion if thats the name, not sure though)
heres an example of my most recent one
http://alexwagner.foto​pic.net/p7446023.html (external link)
you can select full size to have it in full screen.
billhercus
Joined Jul 2002
Sep 24, 2004 08:12 |  #3
I must confess to having far more success with Canon's PhotoStitch than PS's stitch.
Use manual setting (correct for mid pan range) for all shots, overlap by about a third on each photo and it should work well. Occasionally, you might get a light banding effect with a cloudless sky (or I did) which is easily removed with the healing tool.
Experiment! It'll save you a fortune on 10mm lenses :lol:
7D, G1X,
EF70-200 f2.8L IS ll USM,15-85 IS,USM, Nifty 50,Canon EF x 2 lll TC, 580EX, 420EX, 270EX
Elements 11. LR4
Far too much interest in techniques, not nearly enough photographs taken!!
Belmondo
Joined Jul 2003
Sep 24, 2004 08:22 |  #4
/Claire
When you're shooting images with the intent of stitching them together, make sure you use identical settings on the camera for each shot. In other words, shoot manual settings. The camera will change settings as you rotate it if you're in any of the other modes. Also, if you have a CP filter on the camera, remove it. That will change an image as the camera's orientation to the sun changes.
I'm not short. I'm concentrated awesome!
robertwgross
Joined Nov 2002
Sep 24, 2004 10:47 |  #5
Maybe it's just me, but I find my worst panoramic stitchings are those where I used the widest lens. It might be from wide angle distortions near the corners. When I confine my shots to more medium lenses, the problem eases up.
---Bob Gross---
1,820 views & 0 likes for this thread, 5 members have posted to it.
1211 guests, 119 members online
