Thread started 31 Dec 2007 (Monday) 16:18
replication of painting with dslr
bowlesbe
Dec 31, 2007 16:18 |  #1
Hey everyone,
My mom likes to paint watercolors and is interested to replicate her paintings with a dslr. She bought an epson 3800 printer for precisely this purpose. She is having some difficulty though replicating the colours precisely, and getting the white balance right. No combination of camera settings, or lightroom adjustments, seem to result in an exact replica of the original painting.
Does anyone have any insight on whether this is possible, or if so, any suggestions/ recommendations? I realize this may not be easy and special expertise / a scanner, may be required.
Thanks!
*the perfect crop setup*
30d / 10-22 / 17-50 / 60 macro / 70-300 IS
Baadil
Dec 31, 2007 16:42 |  #2
Have you calibrated your monitors etc and creates a color profile for your monitor as well as using proper color profile for the printer?
(BTW, I know nothing about color profiles. :-) )
Canon EOS 400D Xti (Poor man's 1D,) Canon 50mm 1.8 II, Sigma 55-200mm f/4-5.6, Canon 18-55mm Kit; Canon 17-55mm 2.8 IS
sandpiper
Dec 31, 2007 16:43 as a reply to  @ post 4604432 |  #3
Have your monitor and printer been properly calibrated?
If not, it may look right on the monitor but not be accurate in the actual file.
bowlesbe
Dec 31, 2007 16:45 as a reply to  @ Baadil's post |  #4
Yeah... we're using "Spyder"...
got that one covered.
SkipD
Joined Dec 2002
Dec 31, 2007 17:23 as a reply to  @ post 4604432 |  #5
The first issue is controlling the light so you don't have different kinds of light (daylight, incandescent, fluorescent, flash, etc.) affecting the image. It would be best to use all daylight or a mix of daylight and electronic flash in order to have a broad spectrum of color in the light.
Secondly - you need to somehow make sure that either the camera gets the colors right in the first place or that you have a reference shot taken in the same light so that you can get it right in post-processing.
Third - I would suggest shooting in RAW mode (or RAW plus JPG if you wish) so that you can easily make the color corrections that may be necessary. Tweaking a .JPG image is extremely difficult compared to tweaking a RAW image file.
In addition, you need to control the direction and quality (softness) of the light so that you don't get the light source reflecting back at the camera. This involves selection of the lighting equipment but, and more importantly, positioning of the lighting.
On top of all this, as Sandpiper mentioned above, it's critical to calibrate your monitor and your printer. This will require color-sensing hardware and software to do properly.
Skip Douglas
bowlesbe
Dec 31, 2007 17:29 as a reply to  @ SkipD's post |  #6
Hi SkipD, thanks so much! We did actually calibrate the monitor / printer using Spyder. Right now we do not have much control of lighting; just using the daylight right now as it comes through the window in our basement. We bought lighting equipment but we had a difficult time getting even exposure and getting the white balance right.
Can you suggest a specific type of lights to be used, and a specific means of positioning them? Or would it be better to stick with daylight and improve orientation? Any resources (information wise) you can suggest towards this end would be helpful.
Thanks!
braduardo
Dec 31, 2007 17:52 |  #7
bowlesbe wrote in post #4604794 (external link)
Thanks!
If you are going to be using small light sources (ie. lightbulb) you will want to keep it a ways back from your subject. The further away the light source is, the more evenly the light will fall on your subject.
You may be able to find some inexpensive lighting kits designed for ebay/tabletop work. You can also try shining your lights away from your subject and reflecting them back with white fome-core or something similar. Basically, you want to make your light source as large as possible, so you get even lighting on the subject, without 'hot' spots or glare.
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Dec 31, 2007 21:26 as a reply to  @ post 4604432 |  #8
It may not be possible on a home printer. Monitors/fabric dyes/paint pigments & printer inks all have a different response to the color spectrum & while you can probably get close, you might never be able to get an exact match without going to a professional printer using Pantone inks.
1,471 views & 0 likes for this thread, 6 members have posted to it.
1207 guests, 182 members online
