Thread started 31 Dec 2007 (Monday) 19:40
20D vs 40D in color reproduction
Ralpho
Dec 31, 2007 19:40 |  #1
I recently loaned my backup 20D to a friend, and we shot four basketball games together on the same court, with me using my 40D.
I had both cameras set up to shoot RAW in manual mode with apertures in the vicinity of 2.5 and shutter speed 320. ASA 800. Lenses were 35mm and 85mm. We each used both lenses.
When we got the images on a computer screen there was a big difference in color reproduction. The color in the 40D shots were brighter and richer. Whereas the 20D shots looked washed out in comparison.
Is the 40D that much better at reproducing color? If so, it's a big improvement.
SolidxSnake
Dec 31, 2007 19:43 |  #2
Ralpho wrote in post #4605422 (external link)
How did you process the images? You said you shot RAW. If you shot RAW + JPEG, then make sure to be looking at similarly processed RAW images, not JPEG images.
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
FlyingPete
I am immune
Joined Oct 2003
Dec 31, 2007 19:44 |  #3
That reflects my experiences as well with recently upgrading from a 20D to a 40D. I think most of the differences are around the way the profiles are set up on the cameras, my 20D can produce simular results with a 1 bump up in saturation and contrast in DPP.
Peter Lowden.
EOS R6 and assorted glass
SolidxSnake
Dec 31, 2007 20:59 |  #4
FlyingPete wrote in post #4605440 (external link)
If the camera is shooting more saturated in RAW, then it does not matter, as the profiles are applied to the JPEG images, and not the RAW file. The information is in the RAW file, but only DPP reads that information. If you were to open the file in ACR, it might be the same between the two cameras depending how ACR handles RAW files (I'm not sure if it applies anything automatically to the data from the sensor).
1) RTFM.
2) Repeat Step 1.
Mark_Cohran
Joined Jul 2002
Dec 31, 2007 21:00 |  #5
Either camera can produce nicely saturated images - it just depends on the post-processing. I wouldn't worry so much about the differences between the two with regard for that.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
bigcountry
Dec 31, 2007 21:08 |  #6
this could be the reason:
20D automatically sets pic style to neutral, it is the only one.
40D sets the pic styles to standard, which is what you describe.
but who knows, i like my 40D better than my 5D
Louisville Kentucky Wedding Photographer (external link)
Travel the World and Photograph (external link)
Find me on Facebook (external link)
SolidxSnake
Dec 31, 2007 21:13 |  #7
bigcountry wrote in post #4605818 (external link)
Once again, if shooting in RAW, then this has no effect on the image. Styles are applied only to JPEGs. The data is embedded in the RAW file for DPP to read and apply automatically, but ACR discards this data and only uses the image data in the RAW file, not the processing data.
1) RTFM.
2) Repeat Step 1.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 31, 2007 21:42 |  #8
Raw converters like ACR are not optimized for every camera model. To ensure accurate colour reproduction you can get proper camera profiles here:
http://www.ejphoto.com​/acr_order_page.htm (external link)
AFAIK if you use ACR with 20D and 40D camera profiles the colour reproduction should be identical. Without the profiles installed there should be a noticeable difference.
Bob
ae86trueno
Dec 31, 2007 21:50 as a reply to  @ Bob_A's post |  #9
correct me if im wrong, does the 14bits (can't remember of what) does make difference in RAW? (40D 14bit, 30D only 12bit right?)
Andrew
My DeviantArt Site (external link)
Gear Listhttps://photography-on-the.net …?p=1193134&post​count=1513
glowie
Joined Feb 2006
Dec 31, 2007 23:10 |  #10
your friend didn't know how to use the 20D because the 20D owns the 40D in IQ, speed and reliability.
ducks and hides.
>glowie loves you (external link)
>my Flickr (external link)
•The Anti-HDR Movement• (external link)
bigcountry
Jan 01, 2008 10:51 |  #11
SolidxSnake wrote in post #4605841 (external link)
BUT if he is using DPP, then when he pulls up the RAW images, it will show the images w/ a particular style applied. Is this not correct? this is how it works on my machines. Maybe I am color blind though.
René ­ Damkot
Jan 01, 2008 11:29 |  #12
Depends on the Raw converter: DPP will apply the camera settings as 'default'.
bigcountry wrote in post #4608246 (external link)
You're right ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
liza
Jan 01, 2008 11:45 |  #13
I own both cameras and, IMO, the 40D's colors are much better, even with the Neutral picture style. I'm very, very pleased with the 40.
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
SolidxSnake
Jan 01, 2008 13:01 |  #14
René Damkot wrote in post #4608423 (external link)
You're right ;)
Correct, but if using ACR, that doesn't happen. I stated this twice before in the thread. And of course, in DPP, you could set the styles to the same thing instead of picking whatever the camera does automatically.
The best way to test this is to set the 20D to Parameter 2 (everything at 0), and the 40D to.... neutral I believe (I don't have a 40D so I don't know what style on it is equivalent to Parameter 2 of the 20D).
1) RTFM.
2) Repeat Step 1.
René ­ Damkot
Jan 01, 2008 13:49 |  #15
SolidxSnake wrote in post #4608932 (external link)
Sorry, missed that bit :o
8,655 views & 0 likes for this thread, 18 members have posted to it.
1205 guests, 129 members online
