Thread started 01 Jan 2008 (Tuesday) 20:15
Manfrotto 055XPROB
rakesh
Jan 01, 2008 20:15 |  #1
Hi
Recently I bought Manfrotto 055XPROB.
As per the documentation it states that min. height can be 10 cm but I'm unable to do so, b'cos of Centre column itself.
Can anyone advise me on how to remove the Centre column so that I can fix my 488RC4 Ball head directly on the base part instead of Fixing it on the Centre column.
A quick reply is expected from the experts.
Regards
Rakesh
Gears:
My WildLife Gallery :
http://www.justwildlif​e.com (external link)
My Kids Project Galleries : http://www.facebook.co​m …otography/15851​1907574485 (external link)
ben_r_
-POTN's Three legged Support-
Jan 02, 2008 00:05 |  #2
I think what they mean is when the center column is in the horizontal orientation and the head is angled up (in portraiture orientation) you can get a lot lower to the ground. Does that make sense? If not, pull the center column up all the way, press the button in on the bottom of it and pull it out then rotate it so its in the horizontal position. Youll get what I mean then.
rakesh
Jan 02, 2008 04:53 as a reply to  @ ben_r_'s post |  #3
Dear Ben_r_
The procedure I know already but what I mean isthat I want to completely remove the Centre Column alongwith its Horizontal/Vertical mode adapter and then I want to refix my Ball head.
Regards
Rakesh
Gears:
scot079
Jan 02, 2008 05:16 |  #4
You can take the center column off but you can't put the head on as the head mounts on the center column.
The tripod itself goes all the way down to the ground. It all depends on how big the head is when determining camera height.
rakesh wrote in post #4613114 (external link)
Dear Ben_r_
Regards
Rakesh
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
simwells
Jan 02, 2008 05:44 |  #5
Yeah the X version doesn't have the facility to do what you are saying, you just have to put the centre column horizontal.
GregFarz78
Jan 02, 2008 07:57 |  #6
The Manfrotto 055XPROB is basically the same as the old 3021pro right? If thats the case my center column unscrews into 2 parts so I can get close to the ground.
Canon XT
Canon 50mm f1.4 | Sigma 17-70 f2.8-4.5 | Canon 10-22 f3.5-4.5
yoshiguy
Jan 02, 2008 08:30 as a reply to  @ GregFarz78's post |  #7
If someone can take a picture of this configuration it would help alot
Digital Camera Blog - Coolfix.Net (external link)
Canon 40D - 580EX II
rakesh
Jan 02, 2008 08:37 as a reply to  @ yoshiguy's post |  #8
Dear All
I've sent a mail to Manfrotto two days ago but still they hven't replied.
Waiting for theiur reply as well on this.
Regards
Rakesh
Gears:
scot079
Jan 02, 2008 08:37 |  #9
GregFarz78 wrote in post #4613601 (external link)
The 055XPROB does not require that you take apart the center column to go horizontal, it just flips over with the push of a button. The 190XPROB does the same thing, it's just a shorter, less beefy version of the 055.
Here's a picture I found with a quick Google:
Content warning: script
BTW Greg, yes the 055 is the newer version of the 3021.
- Tim
GEARandFEEDBACK
ben_r_
Jan 02, 2008 09:17 |  #10
There is also this deal here, but Im not sure that it works with the 055XPRO...
IMAGE: http://www.bhphotovideo.com/images/largeimages/314610.jpg
LINK (external link)
simwells
Jan 02, 2008 11:27 |  #11
There is no way of doing what you want to do, you just have to put the centre column horizontal with the X models.
There's a thread which talks about it here; https://photography-on-the.net …/showthread.php​?p=4503267
Medic85
I just quoted Forrest Gump!
Jan 02, 2008 11:32 |  #12
Dear Ben_r_
Regards
Rakesh
I don't think that's going to be possible.
Elton ­ Balch
Gallery: 11 photos
Jan 02, 2008 12:01 |  #13
It should be the same as the 3021 which I also have, but if it's not, you can purchase shorter column pieces for about $25.
Elton Balch
5D Mark III, 7D Mark II, 24 mm f/1.4 L, 35 mm f/1.4 L, 50 mm f/1.2 L, 85 mm f/1.2 L, 100 mm f/2.8 macro, 135 mm f/2 L, 300 mm f/4 L, 16-35 f/4 L IS, 24-70 f/4 L IS, 24-105 f/4 L IS, 70-200 f/2.8 L IS II, 100-400 f/4.5-5.6 L IS ii, 580 EX Flash, Speedlight 600 EX RT, 1.4 extender, extension tubes and other stuff.
simwells
Jan 02, 2008 12:08 |  #14
Elton Balch wrote in post #4615085 (external link)
No the 3021 is the same as the 055PRO, not the 055XPRO which has a different centre column system entirely
GregFarz78
Jan 02, 2008 12:22 |  #15
scot079 wrote in post #4613789 (external link)
wow thats a nice feature...I missed the X in the model name
Canon XT
8,050 views & 0 likes for this thread
Manfrotto 055XPROB
1175 guests, 285 members online
