Which CIS Do You or Have You Used?
| POLL: "Which CIS Do You or Have You Used?" |
MediaStreet | 9 31% |
Ink Republic | 6 20.7% |
Lyson | 1 3.4% |
InkJetFly | 3 10.3% |
Kyson | 1 3.4% |
EchoStore | 1 3.4% |
Ebay CIS (please specity + link) | 4 13.8% |
Other (please specify + link) | 4 13.8% |
photosytes Senior Member 419 posts Joined Nov 2005 Location: Ontario, Canada More info | Jan 01, 2008 20:28 | #1 Which CIS Do You or Have You Used? www.earthframed.ca
Jan 01, 2008 20:38 | #2 I've noticed that Continuous Ink Systems have changed alot in the past few years and after doing quite a bit of research, have also found that there are still two very distinct camps when it comes to them (those totally for and those totally against). www.earthframed.ca
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | Jan 01, 2008 20:42 | #3 I've been looking closely at the InkjetFly version. The price is right (ie very low) compared to others but I hesitate based on "you get what you pay for." Did you lose Digital Photo Professional (DPP)? Get it here
Jan 01, 2008 20:48 | #4 I agree. I've found, with the research I've been doing, that if the system works as it claims, even the more expensive systems will pay for themselves in a very short time. For me it's whether the system is going to work well, create accurate colors and that the prints won't fade in a short period of time. Plus I don't want any ink leaking into my printer (which I'm also debating over). www.earthframed.ca
HarleyQuinn Lucky Lucy, or I'm on Crack? You decide. 2,472 posts Joined May 2007 Location: Where the winds come sweeping down the plains... More info | Sounds like we are in the same shopping mode right now. Logging in to follow this thread. Renee
cdifoto Don't get pissy with me 34,090 posts Likes: 44 Joined Dec 2005 More info | Jan 01, 2008 20:58 | #6 Yeah and the problem is they're too expensive to just try one and then another and another. I'm certain they won't refund your money if it's been used already...and fading is a matter of time. Two years later the print could be faded but the warranty/exchange period would have worn out. Did you lose Digital Photo Professional (DPP)? Get it here
Mastineo Member 137 posts Joined Jan 2005 Location: Mansfield,Notts More info | Jan 02, 2008 06:50 | #7 I used the ink republic kit on Epson R800. The system is easy to install, works well and gives very nice prints (even better after having custom profiles made) Ive got prints approaching 2 years old that show no sign of fading. The only problem Ive had is when I didnt print anything for a month and the heads clogged - ended up scrapping the printer.
Jan 02, 2008 08:19 | #8 Mastineo wrote in post #4613399 I used the ink republic kit on Epson R800. The system is easy to install, works well and gives very nice prints (even better after having custom profiles made) Ive got prints approaching 2 years old that show no sign of fading. The only problem Ive had is when I didnt print anything for a month and the heads clogged - ended up scrapping the printer. With regardt to Ink Republics customer service have a quick look at this thread: https://photography-on-the.net/forum/showthread.php?t=424137 John Why did you end up scraping the printer? Just because the heads clogged? Was it due to the kit you were using or for some other reason? Did that kit have the extra tank for the ink waste? www.earthframed.ca
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jan 02, 2008 15:30 | #9 photosytes wrote in post #4611361 I've noticed that Continuous Ink Systems have changed alot in the past few years and after doing quite a bit of research, have also found that there are still two very distinct camps when it comes to them (those totally for and those totally against). I'm wondering who has used them. Who is still using them. How long have you used them. Which brands would you definitely recommend and which you would completely stay away from. Any advice, hints, tips or special considerations you might give others looking into it. Any special techniques, procedures, paper and ink preference, etc. that might improve the overall quality and output. Along with any other information you think might be of use to those of us considering these systems. Here is a review I wrote on my Mediastreet one for my Epson R1800: Obsessive Gear List
Jan 02, 2008 19:45 | #10 What kind of fooling around are you refering to? www.earthframed.ca
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jan 02, 2008 20:27 | #11 photosytes wrote in post #4618489 What kind of fooling around are you refering to? Filling reservoirs, positioning tubing etc... Have you had any problems with leaking? How does the MediaStreet CIS deal with the ink that needs to be purged if you switch from matte to photo black? I noticed Ink Republic offers an extra bottle for such things. No problems with leaking. I purchased a waste ink reservoir from Ink Republic. On the R1800, you don't have to switch blacks, you have them both in separate reservoirs and ink jets. WHere the reservoir comes in is in the cleaning cycles which load up the pad under the head travel area after a number of cleanings. The waste ink doesn't go anywhere it is just soaked up into the sponge. The printer then says that it needs to have parts replaced (i.e. foam pad full of ink). The reservoir obviates the need for this and you then have to software reset the printer (fool it into thinking the pad was replaced) with a program to reset the counter. (also comes under the fooling around comment). I've read your review during my research and know that you are extremely happy with your setup. I'm worried that some people has complained about clogging ruining their printer. Most "clogs" are not "clogs" but bubbles. You can tell by looking at the test pattern - if the blank segments move, it is bubbles not clogs. The other question I had was why are there more options for Epson printers than with Canon ones? I am debating between either Epson R1800/R2400 or Canon Pro9000/Pro9500 but having a good, reliable CIS is definitely part of my decision making process. Two major reasons: Obsessive Gear List
Jan 03, 2008 08:40 | #12 Thanks for the specific answers, John. Good to know about the waste ink reservoir. How exactly do you trick it into thinking the pads have been replaced/resetting the printer? www.earthframed.ca
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jan 03, 2008 17:09 | #13 I really like the R1800. Obsessive Gear List
FeXL Senior Member 493 posts Likes: 3 Joined Dec 2007 More info | Have some questions regarding the cost savings of CIS.
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jan 04, 2008 11:06 | #15 FeXL wrote in post #4629130 Have some questions regarding the cost savings of CIS. To the people who are using them, are you professionals? The reason I ask is, as a professional, I have difficulty trying to rationalize the ROI. There was a number mentioned in one of the above posts about an 80% savings in ink costs. For the sake of argument, let's say that the cost of an 8x10 inkjet print is $1 (using Epson OEM inks and Epson Premium Luster or Premium Glossy paper, ours are actually about half again higher on our R800 and R1800, depending on what we're shooting at the time). Paper is 60 cents, ink is 40 cents. Eighty percent savings on 40 cents results in an ink cost of 8 cents. What do you sell that print for? $25? $50? $100? What is the cost of sales difference on that fifty dollar print between 40 cents and 8 cents? From my perspective, it's negligible. OEM ink too pricey? Raise the cost of your print a buck. Or two. Now I'm not saying that if the price of a cartridge for the R1800 hit $30, I wouldn't seriously consider a CIS. However, with the availability of CIS systems, I don't see that happening. Our PP rate is $125/hour. How long does it take to eat up that 32 cent savings? Fixed costs are essentially a non-issue. I am a semi pro - I shoot both for fun and do sell quite a number of prints (kids sports). I charge about $25 for an 8x10 and $35 for an 11x14. JohnJ80, you speak of longevity. Has anyone (say, Wilhelm) independently tested these CIS inks? I'm not trying to pin your ears back, just trying to get more information. Again, as a professional, print life is very important. Two years is just a drop in the bucket. Fifty years from now I want my clients' archived prints to look as good as they did the day they came off the printer. Yes. MS did testing with Wilhelm. The results are available on their website. I believe they were tested up to 50 years longevity with fading or shifting in color. Testing was stopped at that point (cost) from the discussions I have had with them. You say you can get superior results w/ your ink/paper/profiles over OEM. Any chance you can post examples? I know it's difficult to see minor differences online. Maybe you could describe them? Difficult to post examples - the differences would not show on a web picture. What I do see when looking at the mac's colorsync profiles is slightly larger gamuts on the paper I use (Red River Polar Satin). This, to my eye, has translated into slightly more detail than the OEM prints and a more "3D" sort of look that I like. If you had put as much time into OEM consumables/profiles, would you also have a superior product? Thx for your time. Admittedly, I did not put all this extra effort into coming up with the OEM inks. I did process about 10 cartridge sets of prints on the OEM ink and OEM paper so I think I understand what they are capable of. When my ink costs where hitting about $200 per month, I decided I needed to do something about that - hence the investigation into the OEM inks. I also was frustrated with the cartridge changes mid print and the problems that go with that. There is a fundamental problem with the OEM carts in that they are too small, hold too little ink, and Epson doesn't try and empty them enough (there is considerable ink that remains in the Epson carts when you replace them). So, my main impetus for changing was the cost and the frustration/aggravation. Obsessive Gear List
| Latest registered member is Mihai Bucur 1386 guests, 165 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
