Thread started 03 Jan 2008 (Thursday) 22:57
Why do Alien Bees give off a Pink Tint?
RichNY
Jan 03, 2008 22:57 |  #1
I've been watching people on POTN and other forums posting images with Alien Bees that have one thing in common- Pink Tints. I'm really surprised that people aren't complaining about this as loud as the Mark III focusing issue.
On this forum I've seen Tmrdesign, Curtis, and PacAce recently posting their pink tints. Does anyone have an explanation?
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
bieber
Jan 03, 2008 23:07 |  #2
Examples? I've never noticed any such problem...
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
yendikeno
Gallery: 24 photos
Jan 03, 2008 23:38 as a reply to  @ bieber's post |  #3
Is your monitor calibrated?
_____________
Regards,
AZFred
Curtis ­ N
Master Flasher
Jan 04, 2008 00:04 |  #4
yes, link to some examples, please.
Short of having any specific image to comment on, I would only assert that in the digital age, the color accuracy of an image has a lot to do with the photographer's ability to adjust his white balance to the light source, and little to do with the light source itself.
Looking at the RGB values in the Alienbees shots from this post, the red channel is a touch higher than the green and blue channels in many places. It was shot on AWB and no color correction was done, since color accuracy was unimportant considering the reason I took the shots.
Titus213
Jan 04, 2008 00:09 |  #5
Would you prefer orange? Blue? All equally easy to arrange.
Dave
Perspiring photographer.
AdamLewis
Jan 04, 2008 01:50 |  #6
I dont mean to call anyone out, but Ive thought the same thing. The first person that comes to mind is one person on the board. His images always look a little pink to me
https://photography-on-the.net/forum/showthre​ad.php?t=430751
https://photography-on-the.net/forum/showthre​ad.php?t=423699
cskn0125
Jan 04, 2008 02:24 |  #7
AdamLewis wrote in post #4627392 (external link)
Sorry, but I don't see those as sufficient examples considering that is not a controlled environment (not a studio) As you can see, there is orange everywhere and plenty of other things for the light to bounce off of and reflect on the subjects.
I've never had this problem - Do you have any examples Rich?
PORTFOLIOexternal link // FACEBOOKexternal link // TWITTERexternal link // BLOGexternal link
SkipD
Joined Dec 2002
Jan 04, 2008 03:12 |  #8
RichNY wrote in post #4626603 (external link)
I've been sitting back watching people on POTN and other forums posting images with Alien Bees that have one thing in common- Pink Tints. I'm really surprised that people aren't complaining about this as loud as the Mark III focusing issue.
Is your monitor calibrated using a colorimeter? If not, then you may be seeing everything incorrectly.
Skip Douglas
RichNY
Jan 04, 2008 08:21 |  #9
Curtis N wrote in post #4626911 (external link)
Curtis- This is the post that I was referring to when commenting on both your AB images and Leo's having a pink tint to them. Robert (tmrdesign) has also posted some and I'm sure he can post his here as well. I think they were back when he was dealing with calibrating his meter.
What I find interesting is that the 580 flash didn't show show a pink cast- I would have expected both lights to be similar. To eliminate AWB being the issue can you shoot your card again with the AB and a custom white balance set? I believe you will see similar results.
PacAce
Joined Feb 2003
Jan 04, 2008 08:24 |  #10
I don't know about the others but in my case, when I'm just shooting for the sake of having sample images using the AB, I don't PP those images other than resize and maybe sharpen after resizing. And the camera is usually set to AWB which I won't bother changing. So that may explain it. When I use the flash shot into an umbrella fired via a PW, I notice the same type of a thing except that the image is bluer. When I set the WB to flash, then the image color comes out a little truer. I'll see if that's the case with the AB when I get home tonight. If so, I'll make it a point to always use the Flash WB whenever I shoot with the ABs. I guess I just got spoiled by the fact that the 580EX when mounted on the camera automatically sets the WB for me. :|
...Leo
RichNY
Jan 04, 2008 08:45 |  #11
Thanks Leo. This should be easy to see- either shooting a grey card with a CWB set or (AWB) has a pinkish tint or it doesn't.
Curtis ­ N
Master Flasher
Jan 04, 2008 09:06 |  #12
Rich,
I may have a plausible explanation, at least in my case.
Referring again to this post, I agree that examining the RGB values shows a bit more red in the AB shots than in the Speedlite shots.
The white seamless target was hastily setup above a large dining room table with a bright red tablecloth. The flash was near the opposite end of the table.
The AlienBee with its standard reflector threw a wide beam of light, and some of it bounced off the tablecloth. On the other hand, the Speedlite was zoomed enough to keep most of its light from hitting the tablecloth so the amount of bounced light was insignificant.
That's my story, and I'm stickin' to it. ;)
JMHPhotography
Jan 04, 2008 09:34 |  #13
I don't know if there really is such a thing as a completely 100% nuetral 5600K strobe. My strobes (JTL's) lean toward 5350K with umbrellas and 5850K with a softbox. Bare, they are closer to 5500K, but never on 0 for the green/magenta slider. So I always shoot with a Whibal card or with my Expodisc in the studio to create a custom WB.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
kuanyu
Jan 04, 2008 09:37 |  #14
I have never noticed this, we need a controled studio to test it. Although I own a few Alien Bees the only place I get to shoot has dark red walls. Any Alien Bees owner have access to a white or black studio to test and post the results?
50D & XTi w/Grip - Kit 18-55mm,75-300mm,EF 24-85 IS, 50mm 1.8, 100mm 2.8 macro, 100-400L,580ex,RC-1,(2) AB400s, RF602s ,SoftBox/Barndoors/Brol​ly Box/Sekonic L-308S Lightmeter
empty wallet:(
Kuanyu.zenfolio.com (external link)
PacAce
Joined Feb 2003
Jan 04, 2008 10:10 |  #15
RichNY wrote in post #4628499 (external link)
Rich, in that same thread, for the pictures I posted, I should note that the wall was not white or anything close to it. The actually color of that wall is a yellowish beige even though the picture shot with the 580EX shows it as being whitish. So you really can't go by my pictures to determine the color cast of the strobes. The WB was off for both the flash and the strobe but more so for the flash.
...Leo
22,674 views & 0 likes for this thread, 30 members have posted to it.
1338 guests, 136 members online
